What dia. exh. pipe to not loose low end power?
Discussion in 'Performance and Tuning' started by sportsterchop200, Dec 16, 2011.
  1. Dec 16, 2011 at 5:12 PM
    sportsterchop200
    sportsterchop200 [OP] Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    Just currious what exhaust pipe diameter is recomended to not loose bottom end power. I know a straight through muffler with stock 2.25 exhaust pipe is popular and I have read that some 2.5" cat backs loose bottom end and some alledgedly gain bottom end. I would like to hear from people that have experience with a straight through muffler and these size pipes. I primarily drive at 3000 RPM or less so bottom end power is important. I previously had an 06 Tundra and the recomendation was to keep the stock pipe and just swap the muffler. The exhaust pipe was
    2 3/8". I was thinking of maybe cutting up a factory Tundra exhaust and puting a straight through muffler. Thanks in advance for all opinions and information. My truck is an 03 Tacoma TRD 4x4 with the 3.4L.
  2. Dec 16, 2011 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Only exhaust I have seen that keeps the stock pwer in the low RPM's has been Borla, and TRD exhausts. Otherwise, OEM pipe is best for not loosing any bottom end. 2.5" gives a very slight decrease (within the margin of error of the dyno in my tests), but a good gain up top (about 5 hp, depending on muffler used).
  3. Dec 16, 2011 at 7:38 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    keep it stock
  4. Dec 17, 2011 at 2:36 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Just to throw this out there, the y-pipe, is 2.25" diameter tubing. The OEM catback is also 2.25" diameter. Considering that two tubes of 2.25" tubing (each side of Y-pipe) enter one 2.25" tube, you can see where the restriction is. The catback should be upgraded to at least 2.5" tubing. Pick you brand by your taste.
    Side topic, I run 3" that increases to 3.5" catback. :D
  5. Dec 17, 2011 at 2:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    I retract my description. I didn't read what year yours is until after my post.
