What did I mess up??
Discussion in '1st Gen. Tacomas (1995-2004)' started by HunterMcC1, May 25, 2024.
  1. May 25, 2024 at 5:33 PM
    HunterMcC1
    HunterMcC1 [OP] Member
    1997 Beater Taco
    Looking for some guidance before I start throwing parts at my truck or take it to the shop. My truck is a 1997 with a 2.7… coil ignition… Here’s what happened: I began the undertaking of adjusting my valve shims. I pulled and measured each shim and ordered the appropriate replacements from LCE. However, once I put everything back together my truck now will not idle and I have a misfire on every cylinder… I thought I potentially broke the water temp sensor in the back of the head… however I replaced that and it did not fix the problem… I’ve visually check all my vacuum lines and they are all in place, all connectors have been unplugged and plugged together again to ensure a clicking noise…
    not sure what the problem could be and I’m now more confused after reading through all of the posts about misfires/rough idling… hoping for some guidance… thanks!
  2. May 25, 2024 at 8:05 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    First thing: cam and crank sensors plugged in?
  3. May 25, 2024 at 8:31 PM
    woad4
    woad4 Well-Known Member
    2003 Tacoma Xtra Cab
    3rzfe
    What else did you work on while in there? Just pull the valve cover and replace gasket, and a few shims? Cams never unbolted?
    Did you clean the throttle body while in there? Some people gum up their IAC valve, Re-attach the ground?
  4. May 26, 2024 at 5:58 AM
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    Did you pull the exhaust cam?
    Did you re-check clearances after installing new shims?
    wilcam47 likes this.
  5. May 27, 2024 at 7:41 AM
    HunterMcC1
    1997 Beater Taco
    Did not pull the cam, all sensors are plugged in still… I haven’t installed the new shims yet either… I pulled the valve cover and measured all the shims to order new ones… the truck ran fine before I started this project too
  6. May 27, 2024 at 7:42 AM
    HunterMcC1
    1997 Beater Taco
    I did clean the IAC valve as well
  7. May 27, 2024 at 7:43 AM
    HunterMcC1
    1997 Beater Taco
    And the truck ran well after the IAC was cleaned… it has 205,000 miles on it so I figured it was time to go through everything… I cleaned the throttle body and IAC at 200,000 miles… the shim adjustments were next up on my list…
  8. May 27, 2024 at 7:45 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Before I plowed back into it…I would do a leak down test first.
  9. May 27, 2024 at 7:48 AM
    Glamisman
    Glamisman Well-Known Member
    Check the PCV valve and then the plug firing order.
  10. May 27, 2024 at 7:55 AM
    HunterMcC1
    1997 Beater Taco
    Firing order was checked and rechecked… I did a compression test at 200,000 and all cylinders were within 5psi of each other… I also checked all the grounds and plugs that i detached… I’m wondering is it possible I broke a wire in the engine wiring harness?? I was pretty careful moving it when I took the valve cover off…
  11. May 27, 2024 at 7:55 AM
    HunterMcC1
    1997 Beater Taco
    PCV valve was replaced at 200,000 as well…
    Black97v6MT likes this.
  12. May 27, 2024 at 8:01 AM
    Glamisman
    Well, then old school diagnosis it is. Get her running and one by one take a plug wire off to see what cylinders are contributing.
    HunterMcC1[OP] likes this.
  13. May 27, 2024 at 1:04 PM
    w8tdstrgecube
    Brian
    Wisconsin
    Shims back in same order? Any crap between shims and buckets? When I reinstalled and rechecked clearances there was some metallic crap between the shim and bucket on #4 rear and I had no clearance. Cleaning all surfaces fixed it for me.
    Plugs, coils, wires all correct? I’m less familiar with the older ignition style, my truck has coil packs.
    Engine ground near rear passenger side of valve cover?
