What did you spend to have your clutch replaced (manual)?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rob feature, Dec 7, 2019.
  1. Dec 7, 2019 at 2:24 PM
    rob feature
    rob feature [OP] Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    At almost 200k miles, it's time to replace the clutch in my 2003 V6 4x4 xcab. My garage isn't big enough to tackle this job nor do I think I want to do it. I was hoping to get a feel for what I'm about to spend. I want to hire the best mechanic I can find to do this and don't mind paying the premium. Just from watching Timmy the tool guy's videos I can see this is a tough job. I'd expect to pay maybe 2 grand for this all in - allowing for lots of replacement parts, bearings, & other stuff the wrench will find on the way in that wasn't expected. If it's a wear item I plan to replace it.
    Does this sound like a realistic expectation? Am I over/underestimating? I plan to drive this truck for many more years as everything else is in great shape. I hope I never have to sell it actually. But for now this is my daily driver, my only vehicle, and I want it in tip top shape.
    GQ7227 likes this.
  2. Dec 7, 2019 at 2:58 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I was quoted $1200-1500 to replace a clutch and input bearing from a local independent transmission shop here in town. $2000 sounds a little high to me, but that could be a fair price depending on what parts you get replaced.
    Hamer95USA and rob feature[OP] like this.
  3. Dec 7, 2019 at 4:41 PM
    rob feature
    Colorado
    Sounds like I'm probably in the ballpark then. Everything here is more expensive than most places. Looking to use all OEM parts FWIW.
    GQ7227 likes this.
  4. Dec 7, 2019 at 4:53 PM
    chiago
    chiago Well-Known Member
    Chad
    NJ
    2001 Reg Cab Stepside 4x4
    Did mine a few years ago at 170k at a reputable shop.. costs just $1100 here in CA... Dont think it was OEM parts though...
    rob feature[OP] likes this.
  5. Dec 7, 2019 at 4:56 PM
    1997tacomav6
    Denver
    So I had mine done 6 months ago or so
    Since the transmission has to be dropped I had the following done
    Engine Rear main seal
    Transmission front input shaft seal
    Transfer case input seal
    Transmission center mount, there is a plastic type bushing there in the center.
    Redline transmission fluid
    May as well do the gear shift ball bushing too.
    You will save yourself a lot of money now if one of these go bad later.
    All these parts are out and takes very little to do the added maintenance.
    The dealership actually let me supply the parts that I get from another toyota dealership for a lot cheaper
    Cost me around 900 labor plus the parts.
  6. Dec 7, 2019 at 5:11 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so what are the odds of the clutch on mine going first or the Engine rear main seal :notsure: i estimate 70% roughly highway miles so i don't do a whole lot of shifting gears unless stop and go traffic
  7. Dec 7, 2019 at 5:16 PM
    1997tacomav6
    Denver
    Rear main seals don’t go out to often, but if one did it will cost you 800.00 for a 20.00 part and probably destroy the clutch too
    I did have one fail on my Tahoe and cost me 1000.00 on the automatic
    cruiserguy and GQ7227[QUOTED] like this.
  8. Dec 7, 2019 at 5:20 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    thank goodness!
    i have some serious front suspension work i probably must tend to first before that clutch comes knocking
  9. Dec 7, 2019 at 5:21 PM
    1997tacomav6
    Denver
    Typically the clutch will last 250,000 miles or so
    Hamer95USA and GQ7227[QUOTED] like this.
  10. Dec 7, 2019 at 5:31 PM
    mbroughton02
    mbroughton02 Well-Known Member
    Michael
    Cortland, NY
    07 DCLB
    OME 884, 5100s, Wheeler's 1.5" Progressive AAL, Firestone Ride Rite, Fisher Homesteader 7'4" Plow, Heated Seats, Viper 5806v Remote Start / Alarm.
    When I still had my '98 I had the clutch done at a transmission shop in New Jersey and it was about $800. That was in 2011.
    World of difference after it was done. $2k seems high even with OEM parts.
    rob feature[OP] and GQ7227 like this.
  11. Dec 7, 2019 at 5:36 PM
    1997tacomav6
    Denver
    2k is definitely too much
  12. Dec 7, 2019 at 5:36 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    2013 I paid $130 parts and $500 labor
  13. Dec 7, 2019 at 5:54 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    last time i needed or paid for a clutch job was in 1991 :bananadead: don't recall the cost on that but was a lot for a teenager then lol
    iiirc the old car i had gotten used from a 'woman' driver only had maybe 80k miles on it and it started slipping
  14. Dec 7, 2019 at 5:55 PM
    Wulf
    rock raisin
    You don't have to put yourself in quotes like that :luvya:
    Shellshock and GQ7227[QUOTED] like this.
  15. Dec 7, 2019 at 5:56 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    :hattip: you just volunteered to change my front suspension next year
    cruiserguy likes this.
  16. Dec 7, 2019 at 5:58 PM
    Wulf
    rock raisin
    Bring it to me and I'll do it for beers and stuff
  17. Dec 7, 2019 at 5:59 PM
    1997tacomav6
    Denver
    Where were you when I needed the headers done?? I would have had a least a case available or keg :)))
    GQ7227 likes this.
  18. Dec 7, 2019 at 6:00 PM
    Wulf
    rock raisin
    Oh Lord I hated doing my headers. Now they I have better tools and the experience it wouldn't be so bad though
    1997tacomav6[QUOTED] likes this.
  19. Dec 7, 2019 at 6:07 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i will bring steaks too!
    a mini 1st gen taco party in Colorado
    the hardware will be easy to remove 'probably' being soaked in fluid for the rest of the winter
  20. Dec 8, 2019 at 3:52 AM
    Good deal
    Good deal Well-Known Member
    Texas
    I paid $725. Work was done by a tire shop in South Texas. I couldn't tell you whether or not OEM parts were used....probably not.
