what diff. fluid to use???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDfarmerTN, Dec 12, 2009.
  1. Dec 12, 2009 at 12:16 PM
    TRDfarmerTN
    TRDfarmerTN [OP] Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    ok, i have a 08' sr5 4x4, i dont know what rear diff i have? i know theres no buttons inside for a diff lock or anything...i knew that some take a different fluid then otheres, thats why i ask this...
  2. Dec 12, 2009 at 12:42 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    You don't have a LSD diff., if that is what your asking. You can go with Mobil 1 diff oil without the LSD additive. LSD diff will also have a sticker on the cover that says LSD, the sticker is red and white. You shouldn't have that sticker, but you should check anyways.
    Read this thread and it should answer all your questions: http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
  3. Dec 13, 2009 at 8:36 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    He should definately CHECK for the sticker ....
    The LSD was an option and could be on any non TRD 4WD truck.
    I've seen plenty of non TRD's with LSD's on the lots.
  4. Dec 13, 2009 at 8:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2.
  5. Dec 13, 2009 at 8:48 AM
    automoto
    automoto Well-Known Member
    jersey shore
    07 SR5 4X4 AC
    I have a 07' SRD 4x4 non-lsd. I put Redline 75w90 in front/rear diffs and the transfer case. It took about 5.6/5.7 quarts when it was all said and done. Shifts into 4wd a lot smoother now, and doesn't CLUNK.
  6. Dec 13, 2009 at 10:26 AM
    TRDfarmerTN
    thanks guys, when i get time to change it, ill look and see if theres a LSD sticker on it
