What Diff Oil to use in 08 w/e-locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco084gb, Dec 2, 2008.
  1. Dec 2, 2008 at 11:18 AM
    taco084gb
    taco084gb [OP] No matter where you go there you are.
    Galen
    NorCal
    Hello
    I am new to this site and have tried to locate a thread on what diff oil to use in my rear diff w/e-locker? Also what to use in the front Diff w/4x4.The manual only mentions what oil to use with LSD and W/out LSD and dealer said I should half to drain it out and smell it if it has that diff oil smell or not. If no smell it would be 75w90 with synthetic. and if not a 90w. But he said I should bring it in and have them service it. He also said for $400 they could perform my 15,000 mile service and they will do the front and rear diffs and check everything else. I think this is BS. Anyone out there with a few answers would be greatly appreciated.:confused: Thanx:)
  2. Dec 2, 2008 at 1:12 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Any 75w90 gear oil will work for the rear and front differentials and the transfer case. I use Redline 75w90.
  3. Dec 2, 2008 at 5:52 PM
    taco084gb
    Galen
    NorCal
    Thanx for the reply "all on black"
    Now is that Synthetic or not and I am not familiar with Redline oils. Where can you purchase this type of oil at?
    Thanx:)
  4. Dec 2, 2008 at 6:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have been using mobil1 75w90.....synthetic, and you can get it locally....real good stuff there!
  5. Dec 3, 2008 at 7:00 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    damn! $400.00 for the 15k service? should just be an oil change and lube. 30k is the one for all fluid changes and plugs...just did mine. used royal purple 75w-90for the diffs and transfer case. denso iridium spark plugs, all new crush washers & gaskets. i was quoted $500 for the 30k service at my dealer. did it myself with the most premium stuff i could find for less than $200.
    don't know where to get Redline at...maybe here on the net. O'reiley's carries the royal purple. dont think high dollar oil is neccesary, but i'm a top shelf kinda guy when it comes to my truck.
  6. Dec 3, 2008 at 7:08 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    The only place that I've been hearing to not run synthetic is the in the rear differential with limited slip.
  7. Dec 3, 2008 at 7:09 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Yeah X2, I also use Redline 75x90 in my diffs and Tcase, and Redline MT90 in the trans.
    I think the best place to get this iv found is Summitracing.com
  8. Feb 19, 2009 at 5:10 PM
    Punisher
    Punisher Billy Reuben
    Massachusetts
    2008 Access Cab TRD Off-Road
    Summit good source, and can also buy direct from Redline site.
    Costs a little more on the site but you can also buy one of them funny little red funnels whilst there too I guess.
    http://www.redlineoil.com/buyonline.asp?id=3
