What do 5100's do?
Discussion in 'Suspension' started by vataco19, Jan 9, 2011.
  1. Jan 9, 2011 at 5:27 PM
    vataco19
    vataco19 [OP] Member
    I would like to put 285/75/16's on my taco, would 5100's be the way to go? what exactly do they do?
  2. Jan 9, 2011 at 5:30 PM
    Andy2010
    Andy2010 Well-Known Member
    Andy
    Bucks County, Pa
    2010 TRD Sport Mag Grey 4x4
    EGR inline vent visors, Trimmed front mud flaps, Hose clamp mod, AFE Pro-Dry S air filter, Bed mat off my '97, 5100's up front @1.75, Rear TSB, Tow package, Black TRD center caps, Weathertech Digitals, Wet Okole's in front
    They are a better shock that also gives the ability to lift the front of your truck.
  3. Jan 9, 2011 at 5:31 PM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    They are adjustable shocks. You can set the ride height. Use the search button and you will find a TON of info on them. Happy reading.:D
    Oh and welcome to TW!
  4. Jan 9, 2011 at 5:32 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
  5. Jan 9, 2011 at 6:04 PM
    vataco19
    So would the 33's fit if I set them to 2.5?
  6. Jan 9, 2011 at 6:05 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    You will Have to trim some.
  7. Jan 9, 2011 at 6:09 PM
    vataco19
    Even if I got them front & rear? What would I have to do to get the 33's without trimming?
  8. Jan 9, 2011 at 6:12 PM
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    You'll still have rubbing even with the front and rear lifted. You'll have to lift it higher than what the 5100s can go to get those tires and no rub
  9. Jan 9, 2011 at 6:20 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    You need wheels and a higher lift. I have just over 3" of lift with 4.5 BS and I rub.
  10. Jan 9, 2011 at 7:15 PM
    TacoMal
    California
    The 5100s won't give you any lift for the rear. They are only adjustable up front. You need an add a leaf or new leaf packs for lift in the rear.
  11. Jan 10, 2011 at 5:58 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Strictly speaking, if you don't want to trim anything at all, you would need a 6" lift.
    That being said, 3" lift with 33's is a very popular combo. Just need to trim some plastic, and possibly chop the cab mount.
  12. Jan 10, 2011 at 10:32 PM
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    Which Bilsteins come on my 09 trd off road?
  13. Jan 11, 2011 at 4:43 AM
    TexasTacoma37
    Bilstein HD's.
  14. Jan 11, 2011 at 4:54 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Or go with 32s. I have 275/65/18s(32x11) and no rubbing. Some plastic trimmed but cab mount OK.....
  15. Jan 11, 2011 at 5:35 AM
    boxxed
    Denver, CO
    09 Off Road
    Dumb question but can I use the stock Bilstrein HD for a 3 inch lift if Im just going for looks? Or would it be just waste of time?
  16. Jan 11, 2011 at 5:46 AM
    TexasTacoma37
    You could use them and a coil spacer to achieve lift. However, they were not designed to dampen the stiffer spring rate that the spacers induce.
  17. Jan 11, 2011 at 5:59 AM
    boxxed
    Denver, CO
    09 Off Road
    Ok thats cool.. It would be a waste of time. I just didnt no.
    thanks
  18. Jan 11, 2011 at 7:01 AM
    TexasTacoma37
    That being said, plenty of people still do it.
