What do I drop?
Discussion in 'Suspension' started by badguybuster, Apr 3, 2009.
  1. Apr 3, 2009 at 12:24 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Ok, as most of you know by now, I put a 2.5" lift on my 2006 TRD DC. Now that it has been on a couple days, I think I want to go a little bit higher. So I am saving up for some 5100's (set the fronts at .85) and I figure a 1.5" body lift in the rear. That will put the total lift at (3.35 in front) and (3.50 in the rear).
    So, what do I need to lower to make sure everything is honky dory?
    I figure, the front differential (already ordered the kit).
    The sway bar (already ordered the kit).
    What else??
  2. Apr 3, 2009 at 2:15 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I would recommend the wait and see technique....Yoy may not get vibratations or have any problems.
    Go with what you have and then go from there.
  3. Apr 3, 2009 at 2:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....dont do anything yet. if you do happen to get vibes tho...you can go with either axle shims,or you can get a carrier bearing spacer kit.........drop the drive shaft angles a bit.
  4. Apr 3, 2009 at 2:30 PM
    TheSchwartz
    TheSchwartz Well-Known Member
    Aaron
    Smithsburg, MD
    '11 DC/LB SR5 Magnetic Gray
    Avid BullBar, BFG 265/75R16, remote car starter, Slim's HID heads and fogs
    I would not do just a rear body kit, that is going to mess up the lines of the truck. i would reccomend a block or AAL depending on what you already have.
  5. Apr 3, 2009 at 6:08 PM
    badguybuster
    Michael
    already have the AAL on the rear, but may want to go a little higher.
    The AAL's gave me about 2.25", I think I want to go to 3+"
  6. Apr 4, 2009 at 1:22 PM
    TheSchwartz
    Aaron
    Smithsburg, MD
    If you want 3+ total with your AAL then you can go with somthing like this and just find a larger or smaller block (2.25+1.5=3.75)
  7. Apr 4, 2009 at 4:25 PM
    badguybuster
    Michael
    Well, I had my new BFG's put on and all the vibration is gone. Not only that, the tires must have been worn unevenly because the entire lift is completely level now on all (4). They are all sitting at exactly 38.25". I have not had it aligned yet BUT I was driving down a 1/4 mile straight stretch and straightened the wheels and she went about 200 feet before drifting to the right....not bad, eh? I am STILL taking her in to have it checked, just to be safe.
