What do i gain from taller differential gears??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bodhi armor, Jun 20, 2016.
  1. Jun 20, 2016 at 9:22 AM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Ive heard a lot of people talking about swapping out oem gears for taller differential gears ie: 4.88's.
    It makes sence to me if youre going to be doing a lot of trail/rock crawling, but what about a daily driver?
    I run 32" a/t's on my DD tacoma and it runs just fine, a bit more sluggish than standard size tires but not by a large margin. Also my fuel efficiency has taken a noticeable hit.
    Im curious to know what i may benefit from running taller gears.
    I would like the option of running 35"s but feel the drag would just be too heavy.
    Also, how much would this upgrade cost?
  2. Jun 20, 2016 at 9:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    In your MPG calcs have you factored in the error introduced to your speedo/odo?
    This will help you understand the gear changes introduced by tires and differential changes https://www.tacomaworld.com/tirecalc
    A proper gear change will run you around $1k. For the rear.
  3. Jun 20, 2016 at 9:33 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Is it even possible to run 35s on stock diffs?
  4. Jun 20, 2016 at 9:35 AM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    You will put less stress on your transmission when running larger tires with taller gears. I have 35's and 4.88's and love it. I don't DD my truck cuz I drive my wife's car to work but even on the highway it's not so bad. Your truck with 35's on stock gears, those gears are going to have a harder time turning those large tires thus putting stress on your Trans. Taller gears will help those big tires rotate better. When I had 33's on stock gears my truck was pretty sluggish. I moved up to 35's and 4.88's and gained a lot of low end back. I'm not the fastest guy going down the highway but that's not what I care about haha.
    If you decide to go 35's you'll definitely wanna regear. If you order your 3rd from ECGS they will build your diff for you and send it to you. You can then swap it out yourself (pretty easy) and send your core back to them to get some money back. Hope some of this helps
    DustStorm4x4 likes this.
  5. Jun 20, 2016 at 9:41 AM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    If you go to a larger tire, you effectively change your rear axle ratio. The combination of regearing to a higher numerical ratio and the taller tires returns your truck to closer to the original ratio, allowing you to run the same revs and have the same pulling power as in the original condition.
  6. Jun 20, 2016 at 9:43 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
  7. Jun 20, 2016 at 10:44 AM
    Pigpen
    Dan
    Northwest Montana
    Interesting. It tells me that 4.10 will be ever so slightly lower geared with my 33s than stock with 30.5 tires. Perfect.
  8. Jul 31, 2016 at 9:22 AM
    bodhi armor
    Joshua
    East TX
    When I upgraded to a larger tire size 30" - 32" there was a noticeable drop in fuel efficency. If i regear ill start running 33" maybe 35"
    If a taller gear ration reduces stress on the transmision, will it also reduce the loss in fuel efficency?
  9. Jul 31, 2016 at 9:35 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Yes regearing not only brings back lost power but also increases your fuel mileage as you're not lugging the engine
    Here's another chart showing optimal gearing for tire size ......
    http://www.morris4x4center.com/jeep-tires/tire-gear-ratio-chart.htm?gclid=CKL5vK_Go8wCFU6BfgodkBILZg
  10. Jul 31, 2016 at 9:39 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    4.88's would be shorter/lower gears than stock. Shorter gears give you more torque at the wheels. Also helps offset the loss of torque due to having larger tires.
  11. Jul 31, 2016 at 9:41 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    ^ .. ... this !!!
  12. Jul 31, 2016 at 4:12 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Hell I'm going 4:10s with 265-75-16s. ARB's front and rear.
  13. Aug 1, 2016 at 7:27 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Not completely - you're spinning larger/heavier tires so there is still some fuel cost.
  14. Aug 1, 2016 at 10:05 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    If you're rock crawling I would go to a 4.88 gear then get a Marlin Crawler dual case set up with 2.28 geared box and a 4.70 gear box and enjoy crawling slowly !!
  15. Aug 1, 2016 at 10:34 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  16. Aug 1, 2016 at 11:01 PM
    blubuckaroo
    blubuckaroo Well-Known Member
    Mark
    Ridgefield WA
    1012 LWB 4DR 4X4 TRD
    Roll-N-Lock
    These gear ratio/tire size RPM calculators are only accurate if you input the actual dynamic tire diameter. You have to measure the radius of the wheel to the ground with the weight of the vehicle on it and multiply that times 2. You'll come up with the true running diameter. It is usually at least a couple inches smaller than the advertised diameter.
    This may not seem important, but it makes a considerable difference when selecting a gear ratio.
  17. Aug 1, 2016 at 11:17 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    I have heard that before but Im not sure I buy it. A true 33" tire has a circumference of 103.7" whether it is aired down to 5 psi or up to 75 psi. No matter what, every lineal inch of the tire tread touches the road for the wheel to make a complete revolution.
    jowybyo likes this.
  18. Aug 2, 2016 at 2:51 AM
    bodhi armor
    Joshua
    East TX
    No crawling or serious wheeling.
    DD that is often used in open fields and rough country roads, some of which wash out regularly.
  19. Aug 2, 2016 at 3:11 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Typically, "Taller" would mean higher gears, ie lower numerical gears in automotive vernacular. Lower gearing (higher numerically) would be what I'm assuming you are after. What THAT would give you is more torque amplification....taking load off engine at a given speed in a given gear...
    JDM likes this.
  20. Aug 2, 2016 at 5:32 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    I completely agree. If you DON'T- just look at tire specs (ie Tire Rack or tire manufacturer) for the tire's revolutions per mile. Use 3.1416 to convert revolutions per mile (circumference) to diameter - this is the dynamic tire diameter.
    There is a difference between a steel "tire" - ie on a railroad car, and a rubber tire - the weight of the load changes the diameter of rubber tire. Or measure diameter of the tire and wheel before you put it on the vehicle. Then measure when mounted - the tire with vehicle weight on it will have a smaller diameter.
    Example Michelin MX2 P245/75-16
    Mich spec overall diameter=30.47 inches, rev per mile 683
    Divide 5280 by 683 you get a circumference of 7.7306 feet (1 revolution)
    Divide 7.7306 by 3.14159 and you get a diameter of 2.4607 feet
    Multiply 2.4607 by 12 gives you a diameter of 29.53 inches
    As blubuckaroo said, about 2 inches smaller than the advertised diameter.
