What do i need to run 33's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by espdtrd08, Jun 12, 2010.
  1. Jun 12, 2010 at 8:43 AM
    espdtrd08
    espdtrd08 [OP] espdtrd12
    Virginia
    2012 4runner w/ kdss
    Icon lift, 285 duratracs, shrockworks sliders, weathertechs, leds throughout, Gobi rack w/ladder, rigid driving fog lights, trd shift knob for extra hp, MGM hood vinyl wrap
    I have an 08 TRD offroad dc. Want to put a lift enough to run a 33 inch tire. Thank u TacomaWorld.:taco:
  2. Jun 12, 2010 at 8:44 AM
    Brunes
    Brunes abides.
    Rotorhead
    About a 3 inch lift and some trimming, possibly up to and including getting your cab mounts boxed.
  3. Jun 12, 2010 at 8:46 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Yep. What he said. An easy way to do it is to get you some OME 885's and toytec top plates. Plus, an AAL for the rear.
  4. Jun 12, 2010 at 8:47 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
  5. Jun 12, 2010 at 9:07 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    I would think 4.5" or more to clear w/o cutting body mounts. I have 2.5" and 285/65-18 (32.87" i think), and rub my body mounts when in reverse.
  6. Jun 12, 2010 at 9:15 AM
    callahansd
    callahansd Guest
    im running 33s with a 3inch spacer/aal kit, i dont rub at all on my body but just a tiny bit on my UCAs, so youll need new control arms if you cant deal with a little rub
  7. Jun 12, 2010 at 10:32 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    Well you probably haven't cycled your suspension enough to make it rub yet!
    The fact is that the space isn't enough for 33" tires, regardless of the amount of lift you put. The cab mounts are a stupid design!:mad:
    If you run a high clearance front bumper you will be able to move your tire further forward, to minimize the rubbing. A bigger lift will also give you more room to play, but it still can rub. (Stock tires can rub!)
    It just depends on how you drive.
    Just decide on what you want? And "sack up" and do it!:D
    Take care of any issue that arises! :thumbsup: i.e. rubbing, alignment, etc.........
    If you don't have the time or the money to take care of these issues? Then keep it stock and enjoy the truck!;)
    No lift or alteration to the vehicle is easy, or clear cut! You will have unique issue, because of the fact that the suspension is so "tweakable"
    2 people could have identical lifts, but their trucks can drive totally different! Depending on how it is set up.
    Good Luck man!
  8. Jun 12, 2010 at 4:31 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I thought you could run the 255's in 33's with minimal rubbing except the flaps or do you want a nice fat tire?
  9. Jun 12, 2010 at 6:23 PM
    callahansd
    callahansd Guest
    is 50k miles and living in the mtns good enough cycling? tough country 3in is plenty and cheap, but yes it is a cheap way to make 33's work
  10. Jun 12, 2010 at 6:30 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    I had 33's and I had to cut my cab mounts, had to butcher my front bumper wheel well, and part of the front rear of the fender, and still had rubbing at
    full cycle when going up a driveway at any speed above 10mph.
    My 0.02 cents is don't run 33's, go with 275's
  11. Jun 17, 2010 at 5:57 PM
    espdtrd08
    Virginia
    What's the biggest tire i can run with just some 5100's. Seems like a lot just to run 33's. I had a rubicon and did good with a spring lift. Solid axle is much better imo.
  12. Jun 17, 2010 at 5:58 PM
    Jason'sLawnCare
    Yep:(
  13. Jun 17, 2010 at 5:59 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    well to run 33s, you must 1st use the "search" function lol!
    2.5 to 3" of lift with new UCAs :cool:
  14. Jun 17, 2010 at 6:53 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Can someone translate the 33 measuring unit into something I can comprehend? xxx/xxRxx? :)
  15. Jun 17, 2010 at 7:03 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
  16. Jun 17, 2010 at 7:13 PM
    SCFirefighter
    Stephan
    Cary, NC
    I plan on running some sort of 285's on 17" Sport rims. Got the spidertrax spacers.
  17. Jun 17, 2010 at 7:25 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    33" =
    285/70/17
    285/75/16
    305/65/17
    285/65/18
    etc etc etc
    check it out here
    http://www.tacomaworld.com/forum/tirecalc.php
    btw... I run 305/65/17 with a 4.5" lift with no problems
