What do I need with new Camburg spindles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevinyankowski123, Nov 29, 2011.
  1. Nov 29, 2011 at 4:11 PM
    kevinyankowski123
    kevinyankowski123 [OP] New Member
    Kevin
    Hacienda Heights
    2011 PreRunner
    nothing yet :(
    I am looking to lift my PreRunner and i was wondering if there is anything i need to buy with the Camburg 4" spindles (http://www.camburg.com/toyota/05-11-tacoma/performance-spindles/). I know i need new brake lines but do i need new shocks or anything? And what else would i need so i can put on 35"? Because i know just a 4" lift in the front wont let me clear the tires, so leafs? or body lift kit? Thank you
  2. Nov 29, 2011 at 4:13 PM
    GoDeacsWFU23
    GoDeacsWFU23 Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    4" will clear 35's
  3. Nov 29, 2011 at 4:15 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
  4. Nov 29, 2011 at 4:23 PM
    Manwithoutaplan
    ID
    you need to get king shocks to complatment the camburg spindle. IF you have questions Ray (Rad) he has this system. He is running General grabbers 33 inch
  5. Feb 9, 2012 at 2:52 PM
    TacomaChris
    TacomaChris Well-Known Member
    You don't need King shocks with Camburgs..I'm running 5100s at .85 with stock UCAs and coils. You go higher than that and you may have issues and need more expensive shit to get your alignment in check.
    FYI 35s WILL rub at full lock. I have 285s and mine rub at full lock in reverse...and that's with almost 5 inches up front
