What do I use to lubricate Ignition key slot?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2020TacomaGuy, Aug 27, 2020.
Thread Status:
Not open for further replies.
  1. Aug 28, 2020 at 7:37 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    teflon, or graphite lubricants work best...
  2. Aug 28, 2020 at 7:47 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Really makes a quick job when bleaching your key slot
  3. Aug 28, 2020 at 8:03 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    :yes:
    davidstacoma likes this.
  4. Aug 28, 2020 at 8:59 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Most of the time the problem isn't the tumbler it's the key. Specifically sharp edges or burrs along the cut edge, smoothing the cut edge with a soft brass wire wheel fixes it many times
    Gunshot-6A[QUOTED] likes this.
  5. Aug 28, 2020 at 9:29 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Don’t use dry graphite lubricant, used that on locks in the house and it gets all over the place. I would use a light amount of a Teflon based lubricant. You might want to try moving your steering wheel a little when you have difficulty inserting the key, to make sure the steering wheel lock isn’t the cause of your problem.
  6. Aug 28, 2020 at 9:43 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    This is terrible advice.
    OP, you probably don't need to do anything. It's a new truck with new keys. It's tight now, but it'll loosen up with use.
Thread Status:
