What do the electronics/wires do in the seatbelt receiver?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sbuck, May 12, 2022.
  1. May 12, 2022 at 7:31 AM
    sbuck
    sbuck [OP] Active Member
    2001 Tacoma
    Recently opened up the driver-side seatbelt buckle receiver (the thing you "plug" the seatbelt into) to clean out some gunk and in the process damaged the wires and little micro-chip looking thing inside.
    What is the purpose of this wiring?
    At the time I was just assuming it had to do with a seatbelt notification sound, but then in thinking back I don't think this truck ever had that sound.
    I've read there is wiring/electronics in the part the seat belt comes out of that is used during a crash to activate a some ultra-fast locking of the seat belt.
    I'm concerned the electronics in the receiver is related to that. If that's the case, I would replace the receiver, but wanted to get some input first out of curiosity.
  2. May 12, 2022 at 7:32 AM
    sbuck
    2001 Tacoma
    Other thought: Could also be related to whether the air bag would go off? That would also be a good motivation to replace it : )
  3. May 12, 2022 at 8:13 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    They just drive the seat belt light on the dashboard as far as I know.
    MalinoisDad and Wulf like this.
  4. May 12, 2022 at 10:19 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Seatbelts rapidly auto retract by explosive charge upon impact in an accident detected by deceleration sensors.
    Wiring will be shielded in yellow on these parts.
    The wiring under seat activates dash light @Andy01DblCabTacoma
  5. May 12, 2022 at 11:40 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It's unclear in service info whether or not the seat belt switch is used by the airbag system, it shows to be connected to it as well as the body ECU (to control the warning light and buzzer) on the wiring diagram but the SRS section in the manual makes no mention of it.
    On newer systems the seatbelt buckle switch tells the airbag module whether or not the seabelt is fastened for deployment calculations, logging and warning light control.
    The pretensioner portion of the seatbelt is in the seatbelt retractor assembly not in the latch side although there are some vehicles that do have it in the latch side.
    SR-71A and Chungas like this.
  6. May 12, 2022 at 4:02 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    Not on first gen Tacomas they don't.
  7. May 12, 2022 at 5:24 PM
    Black DOG Lila
    Virginia
    True, not all 1st gens :hattip:
    If it's got air bags, it's got auto retract.
    Chungas and Area51Runner like this.
  8. May 13, 2022 at 5:52 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    and on that note, time for some documentation because someone is bound to ask how to dispose of those explosive charges on their auto retracting seatbelts... :evil:
  9. May 13, 2022 at 6:06 PM
    Chungas
    Chungas Help! My Ferret has lost its stank!
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    How about that! I learned something today. :thumbsup:
  10. May 13, 2022 at 6:15 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I remember back in the day when working as a tech at Lexus. Another tech had to remove and replace a seat belt.
    He used an impact wrench to loosed the bolt and the auto retract charge went off, scared him shitless. It was funny.
    To the op. The wiring in the "buckle" part that you took apart only tells the car when you buckled your seat belt.
    You should be able to find one cheap at a junkyard but it's weird that your truck seat belt chime doesn't work.
    Andy01DblCabTacoma likes this.
  11. May 14, 2022 at 9:30 AM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    Would've never guessed you would be working with explosives while working on a seat belt. Thanks for the info.
    MalinoisDad likes this.
  12. May 14, 2022 at 11:12 AM
    Area51Runner
    The chime can be disabled - maybe his is.
    Off the top of my head, I don't recall if this is done via OBDII/ECU or if it's like the way we set the alarm/remotes (ignition on/off door open close BS). It can be done though. I remember a dealer tech asking me if I wanted it disabled. I said disabled and haven't heard it since.
    Then again, maybe he just cut a wire lol
  13. May 14, 2022 at 11:44 AM
    ArizonaBrian
    Since I've owned mine it's never been on. Fine with me though.
  14. May 14, 2022 at 12:16 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I don’t think disabling it is an option on anything other than a 3rd gen.
  15. May 14, 2022 at 1:34 PM
    Area51Runner
    My 2002 disagrees :notsure:
    SR-71A likes this.
  16. May 14, 2022 at 3:12 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I didn't think it was possible.
  17. Jun 15, 2022 at 9:14 AM
    sbuck
    2001 Tacoma
    Thanks for the input everyone.
    Based on the replies, it sounds like I'm safe to leave it as is?
    Other notes:
    + Never had a seat belt chime in this truck - before or after damaging the wire in question. I'm the second owner so it's possible first owner had the charm disabled
    + Regarding the seat belt light in the dash - I'm not seeing that light up post the wire being damaged, but it's possible the bulb is just out. I need to pull it apart to replace some of the bulbs in there.
  18. Jun 15, 2022 at 9:36 AM
    Madjik_Man
    Colorado Front Range
    It’s just for the seat belt warning light on the dash. Trace the wires down below the seat and you’ll see it connected to a single white connector that runs under the carpet.
    The seat belt locking feature in case of an accident is all mechanical. Nothing to do with the electronics in the seat belt receiver.
    Air bags are controlled by some electronics that will always be indicated by yellow harnesses/connectors. Again nothing to do with the electronics in the seat belt receiver.
  19. Jun 15, 2022 at 9:39 AM
    Madjik_Man
    You can easily disarm the chime but disconnecting the single wire connector under the seat.
