What do the Sidewall Ratings mean?
Discussion in 'Wheels & Tires' started by Evil Monkey, Nov 15, 2008.
  1. Nov 15, 2008 at 10:30 PM
    Evil Monkey
    Evil Monkey [OP] There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    What do the sidewall ratings mean? For example, I see that Nitto Terra Grapplers come in sidewall ratings of D & E. The price difference on a set I found is $26 per tire (E more expensive). Does this matter for the Tacoma? When would you want the higher rating?
    Thanks
  2. Nov 15, 2008 at 11:16 PM
    kmrofka
    kmrofka Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    i think it relates to load rating... dont quote me on it but i think thats what it is... and obviously e would be the best
  3. Nov 16, 2008 at 12:45 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    C, D, and E are the ratings you'll find on LT tires. the C is a light load rating but is fine on the Tacos. E is the heaviest load rating and is for the 3/4 and 1 ton diesel guys mainly. you can run the D and E range tires but the sidewall is stiffer so they will most likely give a rougher ride and wont conform as well when aired down 4wheelin. I've heard that the higher load range tires have a harder rubber compound and will last longer on the lighter vehicles too. i think usually it'll go 6-8-10 ply ratings from C-D-E too.
  4. Nov 16, 2008 at 9:13 PM
    Evil Monkey
    Robert
    Escondido, CA
    Thanks for the info.
