What do yall think of my new bumper design?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tucker771, Apr 19, 2016.
  1. Apr 19, 2016 at 7:27 AM
    Tucker771
    Tucker771 [OP] Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    Been learning how to use CAD software and this is my first project. what do yall think?
    Burnett likes this.
  2. Apr 19, 2016 at 7:29 AM
    SuperJakeTheSnake
    SuperJakeTheSnake What is this place?
    Jacob
    Jacksonville NC
    02 Toyota Tacoma Prerunner
    Looks good to me, this is just my personal preference but I would try and have the hitch recessed into the bumper
    a.smo and DustStorm4x4 like this.
  3. Apr 19, 2016 at 1:47 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Recessing the hitch in the bumper means laying on the ground to put the pin in till you figure out just how to do it without seeing it.
    I learned this the hard way.
    Design looks good but the only real thing is do you like it.
    Maybe include some real world measurements in case you save this 11 months later you want to build it
  4. Apr 19, 2016 at 1:54 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    To lay under the truck to put a hitch pin in is minor IMO. I'd rather deal with that and keep a good depature angle.
    Bumper looks good OP. What CAD software do you use?
    ChamYota and DustStorm4x4 like this.
  5. Apr 19, 2016 at 1:56 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Oooh, SolidWorks? I should design my bumper. Like yours OP, I would recess the bumper as well, makes sure if you tow or snatch someone that there isn't so much leverage on the main piece as well.
  6. Apr 19, 2016 at 1:56 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    Should have mounting brackets for plate
  7. Apr 19, 2016 at 2:00 PM
    mountain mike
    mountain mike Woodsbum
    the backwoods...
    2003 DCSB 4x4
    just what I need to do what I want
    Where will you mount your license plate? If you recess the hitch then you could hide it with your plate, hinged from the bottom unless that would interfere with your trailer coupler. IDK
  8. Apr 19, 2016 at 3:17 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    OP double check your mounts. They need to be flipped 180 degrees. There are 4 bolts on each side you can utilize to mount it to the frame. 2 on the outer sides of the frame (head of the bolt pointing away from the truck) and 2 on the bottom of the frame (pointing towards the ground). You'll also want to re-inforce the mounts back to the bumper Other than that and the previous comments looks good! Maybe even get some type of wrap around protection.
    I made a bumper like that on solid works as well, just a little different plus a swing out
    a.smo likes this.
  9. Apr 19, 2016 at 9:30 PM
    Tucker771
    Tucker
    Raleigh, NC
    It is solid works and i do have a small problem with the way the hitch is but im stuck between recessing it and having to do more work but gaining structural integrity and keeping it convenient. maybe ill drop the hitch down just a bit more cause ill still have damn good ground clearance and it'll be safer. Still thinking about boxing the rear frame a bit too to help structural integrity.
  10. Apr 19, 2016 at 10:28 PM
    neegdogdig
    3rd Gen DC V6
    image.jpg Give you little help how 'bout like this
  11. Apr 19, 2016 at 10:37 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    What kind of departure angle is REALLY necessary? Unless you're doing serious rock crawling the few degrees of departure angle over the center 6" of your bumper will be irrelevant.
  12. Apr 19, 2016 at 10:39 PM
    Toyko Joe
    I think your design looks pretty good though. Have you thought about putting 1.25" square openings just inside of the frame rails for an auxiliary basket or bike rack?
  13. Apr 20, 2016 at 1:10 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    To each there own but for me laying in a foot of mud to install the pin through the receiver was not in any way fun.
    I was happy to see that truck go
  14. Apr 20, 2016 at 3:15 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Is it really that hard to deal with a hitch pin without looking at it?? I have a relentless bumper with the hidden behind the plate reciever and have never had an issue....
  15. Apr 20, 2016 at 4:54 AM
    Indy
    Indy Master of all I survey.
    I dont think ive ever had to look. It's not that complex.
  16. Apr 20, 2016 at 4:54 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    1st gens stock bumper already have a decent departure angle. So aftermarket doesn't need a lot. 2nd gens have horrible rears. You're angles are fine OP
  17. Apr 20, 2016 at 5:48 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am just quite a klutz then I have no idea just how your bumpers are designed
    This one the hole through the receiver tube was between two pieces of channel the receiver tube ran through.
    really no way to reach in there but from the bottom up with my short arms I could only reach it laying on the ground
  18. Apr 20, 2016 at 6:46 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I would push the receiver in as well so it doesn't drag behind on hills and looks cleaner. It will also make it easier to weld it through the rear of the bumper for additional strength. Make sure the tow rings go through as well and weld to the rear.
  19. Apr 24, 2016 at 8:33 AM
    Tucker771
    Tucker
    Raleigh, NC
    thanks for all the good advice everyone! ill be sure to take it into consideration
  20. Apr 24, 2016 at 12:10 PM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Also...with the hitch receiver sticking out like that, you'll be running into it more times than you would like. It may be only a few inches, but anything metal jutting out seems to be something that every shin/knee seems to hit.
