What do you air down to
Discussion in '1st Gen. Tacomas (1995-2004)' started by Purpleyota, Nov 7, 2019.
  1. Nov 7, 2019 at 8:23 PM
    Purpleyota
    Purpleyota [OP] Well-Known Member
    98 purple Tacoma trd
    Bilstein 6112 up front and 5165 in the rear rock sliders warn winch coustom rear bumper and tg front bumper
    I'm running 285/75/16 bfg ko2 load range e and I was wondering how much to air down for playing in some rocks
  2. Nov 7, 2019 at 8:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If I'm loaded up and there's a trail out to camp, 20psi.
    If it's just to run trails, 15psi.
    I'm rocking 235/85/16 Falken AT3W
  3. Nov 8, 2019 at 11:32 AM
    eon_blue
    Azusa, CA
    15 psi on crawling trails, 20psi on 2wd or 4hi friendly trails
    ~8 psi in sand
    E rated tires are able to be aired down to about 10psi give or take since the sidewalls don't flex and roll as much as a lighter load tire will.
    I would suggest getting a portable air compressor (a good one that connects to the battery terminals directly - not one that plugs into the cig lighter) for airing up after the trail
    Purpleyota[OP] likes this.
  4. Nov 8, 2019 at 12:08 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I just want to reiterate what @eon_blue said.
    15-20 psi for sure. I have my deflators set at 18psi and always start there. If the trail gets harder or I just feel more traction is necessary, I'll go to 15. Never really needed less than that. In sand, I would *start* at 15 psi, and go lower as needed. 10 is pretty good, but keep in mind the lower your pressure, the more likely you will blow a bead. If you get back to a part where you are going faster, air back up a bit.
    That brings me to Ryan's other point. 100% you need a compressor if you will be airing down. Viair is pretty much the "gold standard" for compressors/pumps, and they really aren't that expensive. My 400P was like $150, and is pretty much the size you'd want for those 33's. There's a more budget friendly 88P which technically would work, but it will take longer to inflate per tire, and you're stressing the pump more than necessary. Get a 400P for sure.
    Purpleyota[OP] and eon_blue like this.
  5. Nov 8, 2019 at 1:02 PM
    SFcruiserLife
    SFcruiserLife Well-Known Member
    FZJ80 37’s locked blah blah 1st gen taco dual case d44 crawler
    I’m on 37’s though but I run on steel black wheels (better grip on the beads compared to aluminum)
    normal trail riding 15psi front/12 rear
    Rock terrain( Rubicon) 10psi front/8psi rear
    I’m normally lightly loaded, spare tire in the rear bed, 2 camping boxes, tent/sleeping bag/fold out table/chairs when I go out for a couple of days.
  6. Nov 8, 2019 at 1:10 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I pretty much always run 8psi for the rocks regardless of my wheel/tire setup. Never have broken a bead yet.
    eon_blue likes this.
