What do you all typically replace when you do shocks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ldickersonc, Jul 8, 2022.
  1. Jul 8, 2022 at 2:41 PM
    ldickersonc
    ldickersonc [OP] Member
    My 2015 DCSB has 155k miles, and it's time to do shocks. While I have it up, what are some other components you all recommend replacing? I am doing brake shoes on the back as well. I have heard ball joints and wheel bearings. Any advice?
  2. Jul 8, 2022 at 2:44 PM
    saint277
    saint277 Vigilo Confido
    Don't recommend replacing the joints, it is a good time to check the joints and see if they are loose when you have the shock off, if they are loose change em.
  3. Jul 8, 2022 at 3:07 PM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    Nothing really needs to be replaced at the same time... But there are some things to check
    Check the LCA and UCA bushings to see what shape they are in. It might be hard to see but give them a good yank back and forth and see how easy they move.
    With the wheel still on, grab it at 12 and 6 o'clock and give it a good wiggle. It should be solid af, but if you hear a noise it could indicate ball joints are going bad.
    Once the wheel is off the brake pads are easy to check. And I find it easier to check the wheel bearing with the wheel off too. Just give it a spin by hand and it should feel smooth. If it feels like it's grinding at all then that would indicate it's time for those as well.
    If you have a 4x4, it might be worth looking into doing the ECGS needle bearing fix. You can kinda check this before hand by just getting under the truck and seeing how much play your driver side axel has where it enters the dif. If there's lots of play then it might be a good idea to swap out that needle bearing for the ECGS bushing (typically you will hear a groaning noise when driving if this has gone bad, and switching into 4x4 usually silences it. That's how you know it's the needle bearing). This will require draining and refilling your dif fluid though. Also a good time to check your CV boots for tears.
  4. Jul 8, 2022 at 3:11 PM
    saint277
    Ya just start grabin stuff, if it wobbles give it a closer look.
  5. Jul 8, 2022 at 3:17 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Definitely do not need to drain the diff to do the ECGS.
    My rear brakes went over 200k... just sayin
    Look for torn boots and address any rust.
  6. Jul 8, 2022 at 3:22 PM
    Saskabush
    Adam
    2013 TRD Sport
    Do you not? That sure makes it a bit easier. I haven't actually done mine yet, just started looking into it. Most other vehicles I've pulled the front axels out needed to have the dif drained first.
  7. Jul 8, 2022 at 3:24 PM
    AllTacosFloat
    Boston ish
    Some fluid will come out when you pop the cv, then just top it off when you're done.
    If you need to do a fluid change this would be a good time.
    Last one I did we needed to add 1/2 quart to get it to full.
  8. Jul 8, 2022 at 3:35 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Nothing to add for the rear shocks. On the front, consider replacing the top mounts, see KYB SM5640. Also consider adding a 1/4” poly spacer on the driver side to help offset the Taco lean. If you measure the front height, you’ll see the driver side sits lower than the passenger side. You will be loosening the cambolts; you can check if they are seized so you can replace them, accordingly.
  9. Jul 8, 2022 at 3:36 PM
    ldickersonc
    Follow up,
    Front coils: good practice to replace with the shocks? Do these 'go bad'?
  10. Jul 8, 2022 at 4:06 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    i would check the bushing on the lower contol arm. UCA. and i bet your radiator support bushings are shot as well
    yeah. over time they do. they will start to "sag" or get tried.
  11. Jul 10, 2022 at 6:08 PM
    ldickersonc
    Going Bilstein 4600 all around.
    Is there a way to measure or inspect them when they are out? Is there a minimum height?
