What do you DISLIKE about your Tacoma?
Discussion in 'Product Reviews' started by OFFROADCARWASH, Mar 31, 2009.
  1. Dec 11, 2020 at 6:22 PM
    #1521
    Just84
    Just84 Well-Known Member
    Justin
    2015 Taco
    The mpg in my 2015 is the worst. I fill up half as much in the 07’ Titan I’ve been driving, the past few weeks.
  2. Dec 20, 2020 at 9:28 AM
    #1522
    OpsWest
    OpsWest Well-Known Member
    18 TRD OR
    Perhaps the only thing so far is the engine power band. If only the torque was available earlier it would probably be better.
    Don’t really like needing to hit 4-5k rpms to hit what seems to be peak tq. I did see a tune that made the tq. More available and as a result mpg goes up a bit.
    TRDPRO68 likes this.
  3. Dec 21, 2020 at 6:24 PM
    #1523
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    Stock suspension on the third gen OR. It's great if drive around with no gear. Load it up for the weekend and it's an absolute mess.
    Rottencotton and OpsWest like this.
  4. Dec 21, 2020 at 6:29 PM
    #1524
    Carhanu
    Carhanu Well-Known Member
    Michael
    2020 Red Tacoma TRD Off-Road
    The steering wheel doesn't telescope enough. There is no grab handle on the driver's side a-pillar. You have to replace the needle bearing with a clamshell bushing (which most auto shops either don't know how or refuse to do it) in order to lift your truck without any issues.
    You have to be in 4-low in order to use the locking rear differential.
    The engine/transmission lacks power at low rpms.
    TRDPRO68, Whammo, MJTH and 1 other person like this.
  5. Apr 27, 2021 at 4:45 PM
    #1525
    Which Way Out
    Which Way Out Well-Known Member
    Bill
    Santa Barbara
    2002 Tacoma 4 Door Prerunner
    What I dislike is, worrying that someone will steal it or crash into it.
    Sheld505 likes this.
  6. May 31, 2021 at 10:25 AM
    #1526
    leeroy300
    leeroy300 Well-Known Member
    Brian
    Prince George BC,Canada
    2021 Access cab TRD off road
    TRD lift 265-70-16 Toyo AT'3
    The damn curve from the door to the arm rest
  7. Nov 1, 2021 at 12:47 PM
    #1527
    gregzz
    gregzz Well-Known Member
    greg
    las vegas nv
    2011 tacoma crew cab 4x4 v6 4.0
    Wheels/ tires, tint, level kit. Rock crawler rails. 3- 6" procomp lights with light bar on front bumper. Magnaflow # 12256 stainless muffler. Billet shorty antenna.
    :confused:What do I dislike?? Ummm…. ……. Nothing.
  8. Nov 1, 2021 at 12:51 PM
    #1528
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    After adding winch, armor, wheels and misc stuff, its a 5000 lb vehicle. Spent $$$ to upgrade the brakes and rotors.
  9. Nov 3, 2021 at 5:42 PM
    #1529
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    It bothers me that they are so easy to total.
  10. Nov 3, 2021 at 6:28 PM
    #1530
    Redline870
    Redline870 Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    The reason I traded mine in for a Tundra was the lack of power. It wasn’t an underpowered engine like everyone thinks either, it was the gearing. The KDMax tune fixed a HUGE portion of the horrible OEM transmission shifting, but the gearing is a mechanical issue that can’t be overcome without replacing with Nitro gears. You shouldn’t have to buy a $40k truck just to spend thousands in tuning and regearing just to make it drivable. In stock form it can barely hold 75mph on the highway.
    FlyingWolfe likes this.
  11. Nov 3, 2021 at 6:38 PM
    #1531
    svendough
    svendough Well-Known Member
    Colorado
    2020 Cement DCSB OR
    Skinny rubber, Bilstein lift, iKamper
    MPGs. Honestly everything else is just great. All vehicles are expensive these days, and I'd find something to dislike about any other vehicle...guaranteed. But I feel like it should be easier to average 20mpg without driving like I have a depth perception problem.
    Also, not much to dislike when you're sitting on an easy resale.
    TRDPRO68 and texas angler like this.
  12. Nov 3, 2021 at 6:52 PM
    #1532
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I wish it had come with the lighted ignition key ring and no tpms crap.
    Rottencotton likes this.
  13. Nov 8, 2021 at 7:35 AM
    #1533
    manfred twd
    manfred twd Active Member
    mike
    2021 trd takoma
    My truck won't lock if the powered back window is open a bit when I leave it in the sun. WTH?
  14. Nov 13, 2021 at 6:30 AM
    #1534
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I hate the squeaky door seals during cold and dry weather
  15. Nov 24, 2021 at 7:35 AM
    #1535
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The crappy GY Wrangler SRAs on the truck.
    Due to budget, I need to run these slippers until they are worn out. Although it shouldn't be too long, the treadwear only has a 560 UTOG rating and these were made in 2015.
    bush rat likes this.
  16. Feb 3, 2022 at 5:47 AM
    #1536
    jtibi1992
    jtibi1992 Member
    Jacob
    2020 White Toyota Tacoma TRD Offroad DoubleCab/ShortBed
    The $25000 i still owe
    Edit: And yes the crappy stock tires that come on it. Popped three of them before I splurged on some BFG KO2s
  17. Feb 3, 2022 at 5:49 AM
    #1537
    Dood86
    Dood86 Well-Known Member
    Kyle
    Everett, Washington
    21 tacoma sr long bed 2wd
    Led lights
    That I have to buy my own gas!
  18. Feb 3, 2022 at 5:52 AM
    #1538
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    The only thing I dislike about my Taco is that it isn't available with an inline diesel. A torq-ey, low revving little, balanced diesel in I-4 or I-6 configuration. Every Aussie off road vid I see on YT has these beautiful off road rigs pulling caravans with their Yota's heart beating with diesel. That's the only thing I dislike.
    When I win the Lottery I'm going to have a shop specializing in diesel conversions.
    scouterjan likes this.
  19. Feb 3, 2022 at 5:59 AM
    #1539
    Rottencotton
    Stinkin Rincon
    When I win the Lottery I'll buy one of these.
    davidstacoma likes this.
  20. Feb 5, 2022 at 3:04 AM
    #1540
    SURFRATT
    SURFRATT Well-Known Member
    Cabin wind noise at high speeds
    Stock speakers sound terrible(need to upgrade on my own)
    Lenny Dykstradamus likes this.
