What do you do first to your new truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RNILT, May 29, 2022.
  1. Jun 5, 2022 at 4:52 PM
    #221
    huskcummerbund
    huskcummerbund Well-Known Member
    2020 TRD-OR MT
    Just little pieces of plastic and double-sided tape that keep the tag lights from shining directly into the backup camera at night and throwing off the ISO setting. You'll probably notice that the backup camera appears "snowy" at night but if you turn off your headlights it looks a lot better. It's the tag lights. Couple bucks, or even a couple strips of black duct tape pretty much fixes an "only annoying once some asshole on Tacoma World points it out" design flaw.
    https://www.tacomaworld.com/threads/3rd-gen-cheap-easy-license-plate-light-glare-fix.739648/
    djembefola and RNILT[QUOTED][OP] like this.
  2. Jun 5, 2022 at 4:52 PM
    #222
    RNILT
    RNILT [OP] Well-Known Member
    Luke
    2022 TRD Off-Road DCLB Barcelona Red
    Man, sounds like you were ready to go with the new truck - got it well outfitted. How do you like your Leer 122? And are you happy with the rokblokz flaps?
  3. Jun 5, 2022 at 4:58 PM
    #223
    RNILT
    Luke
    Thanks. Someone mentioned it but I’m still trying to understand if I need it here in the desert in AZ?
  4. Jun 5, 2022 at 4:59 PM
    #224
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I do it randomly here and there. But definitely not absolutely necessary imo.
    RNILT[QUOTED][OP] likes this.
  5. Jun 5, 2022 at 4:59 PM
    #225
    RNILT
    Luke
    What did you change yours to? I’ve seen a couple folks mentioned swapping them out.
  6. Jun 5, 2022 at 5:12 PM
    #226
    RNILT
    Luke
    Super cool and useful, thanks. I have so many questions Lol How hard was it to replace the side bed decals? Concerned about getting the originals off and getting the new ones on in the right position and straight.
    Also, I’ve seen the AC drain tube fix mentioned in forums. Is that something I can get a mechanic/shop to do? I’m admittedly not handy at all.
    And finally, are you happy with your bike mounts? I’ve started researching options. My wife has a Townie cruiser-type e-bike that’s heavier/thicker than my basic hybrid bike, so that’s a primary factor. I’m getting a long bed and like the idea of using the bed to haul the bikes, but especially since this is my first truck, I haven’t figured out how that will work.
  7. Jun 5, 2022 at 5:44 PM
    #227
    huskcummerbund
    2020 TRD-OR MT
  8. Jun 5, 2022 at 8:17 PM
    #228
    marcamos
    marcamos Well-Known Member
    Marc
    Beverly, Massachusetts
    2021 Off Road 6MT
    Before I took them off, I took close-up photos of the factory stickers, and also put a strip of painters tape around them, right up against their edges.
    Then, with a regular hair dryer, I simply heated them up quite a bit and slooooowly/caaaaarefully pulled them off.
    A little Goo-Gone and a thorough wash later, and the new stickers were ready to go on.
    Putting them on was a little nerve-wracking because I wanted them to be perfectly aligned and in the exact same positions; I went slowly, used the tape as guides, and it all worked out to my satisfaction.
    Probably? It’s fairly easy, personally: you zip-tie the existing factory hose to one side of an aluminum coupling, then zip-tie the other supplied hose to the other side of the coupling … boom, you're practically done. From there, send that lengthened hose down under the truck, zip-tie it to something, then cut it so it’s not hanging too far towards the ground.
    Honestly, the toughest part was getting on the step ladder and reaching down into the engine bay.
    These mounts are wonderful and definitely my preferred way to carry a couple of bikes; but I understand it’s very subjective/situational.
    I’m not sure if they’d work for the bike you mentioned, especially if the spots these mounts grab onto are an uncommonly thick diameter tube?
  9. Jun 6, 2022 at 12:12 PM
    #229
    RNILT
    Luke
    Awesome, thanks for all the info, appreciate your time. Good call about the rack - need to check where the mounts grab and the wife’s bike’s tube diameter.
    marcamos[QUOTED] likes this.
  10. Jun 6, 2022 at 12:25 PM
    #230
    RNILT
    Luke
    What tune did you do? I know nothing about tunes. I’ll have an AT and have heard about KDMax but really am admittedly ignorant when it comes to the subject.
  11. Jun 6, 2022 at 12:26 PM
    #231
    RNILT
    Luke
    Meant to ask, what tune did you do? I’m a total novice about tunes, just starting to read about them.
  12. Jun 6, 2022 at 12:28 PM
    #232
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    I did KDMAX, you can find everything you need on page 1 as they do update the first post. Do read through the entire thread if you want but it's just amazing.
    KDMAX-PRO+XT Tune by @PapaRee and @TWtaco | Tacoma World
    I currently have the KMDAX Pro but soon will be updating to KDMAX Pro+XT.
  13. Jun 6, 2022 at 12:37 PM
    #233
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    I went with the KD Max tune, sport mode. Couldn’t be happier. There was a tuner not too far from me so we met up and got it done. They have a updated version now that I’m going to try called the “XT”… Honestly I hated this truck right off the lot. No low end torque. I drove v-8’s most of my life so I wasn’t used to this v-6. The tune fixed that and I love driving it now. Hope this helps…p.s., read the tune threads on here and educate yourself before committing to any tune. There’s lots of good tunes out there. Good luck!
  14. Jun 6, 2022 at 3:41 PM
    #234
    Asada
    Asada Well-Known Member
    Richard
    2021 White DCLB TRD Sport
    Blackout Kit OE Power Bank Ceramic Coating and PPF Tonneau Cover and mat
    Le sigh... I wish the closest tuner to me wasnt six hours away. I would sure consider it
    RNILT[OP] likes this.
  15. Jun 6, 2022 at 4:31 PM
    #235
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    First thing for me before any contaminates get on the paint is ceramic coating.
    Wash with heavy auto detergent
    Clay bar (you'd be surprised how rough paint is brand new)
    Polish with ceramic primer
    2-3 layers for good quality ceramic coating
    Boom, solid, pristine paint for at least 2 years.
  16. Jun 8, 2022 at 6:59 PM
    #236
    RNILT
    Luke
    Really helpful, thanks. There’s a KDMax authorized place pretty convenient to me. How much did the tune cost, if you don’t mind my asking? I have no concept of the cost.
  17. Jun 8, 2022 at 7:03 PM
    #237
    RNILT
    Luke
    That definitely helps, thanks. How much did your tune set you back? And how much will the new update be? I have no sense of cost, so pardon my asking. I’m definitely going to read more, for sure, and I’ll be interested to see how I feel driving the new truck off the lot. I’m coming from a decade-old Forester, not V8s so that’s a different perspective Lol
  18. Jun 8, 2022 at 7:52 PM
    #238
    Raijin822
    Canada
    2021 TRD OR
    Contact the tuner near you, I'm in Canada so it's different than the majority of you guys in the states. Either way though it was the best thing ever
  19. Jun 9, 2022 at 4:00 AM
    #239
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    I think it ranges between $350-400 depending on the tuner. Updates should only be $50-75 if that. With the KD max pro “xt” you shouldn’t need an update for awhile I imagine. It’s nice they are constantly tweaking these tunes and making them better. I’m happy with my tune now but I’ll always be curious with the updates, anything to make these trucks drive better. Its by far the best thing I’ve done so far.
  20. Jun 9, 2022 at 11:19 AM
    #240
    sdiver
    sdiver Well-Known Member
    Steven
    Chicago
    2022 TRD Off-Road DCSB
    First thing I did (as I do with all my new vehicles)...carwash, clay bar, a few coats of ceramic coating.
    Then a I drove it for a few days to figure out what I would want/need. The Vehicle OCD glove box & center console organizer was a must, it makes those spaces so much more organized & functional. I also found the OEM radio knobs are kinda awful...so I just ordered a set of the TACOMODS backlit aluminum radio knobs.
