What do you do with leftover 2 stroke premix?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, Oct 30, 2016.
  1. Oct 30, 2016 at 10:18 AM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I got about 8 gallons and I'm thinking of burning it in the truck over the next 2 or 3 filings. Adding 2-3 gallons to 3/4 of a tank. It's mixed 50:1 now and would easily be 700-800:1 when it gets burnt.
    Will this f*** up the cats,O2,and AFR sensors; whatcha think?
  2. Oct 30, 2016 at 10:28 AM
    brah.coma
    brah.coma Well-Known Member
    06 2.7l 5spd 4x4 Reg Cab
    Why don't you put it in your weedwacker?
  3. Oct 30, 2016 at 11:12 AM
    Larzzzz
    Larry
    MA
    For what gets weedwhacked, a gallon for that isn't a bad idea.
  4. Oct 30, 2016 at 11:13 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    I would be more worried about the gas being stale than the two stroke oil. I wouldn't do it but its your truck. If you just want to get rid of it most garages that burn used motor oil for heat can burn it.
    AR15xAR10 likes this.
  5. Oct 30, 2016 at 11:13 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Ive always burned it in my mower/truck
    Shark18, ecoterragaia and Bentrodder like this.
  6. Oct 30, 2016 at 11:14 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    I wouldn't risk running premix in my truck, you're going to run the chance of damaging something for $16-20 worth of gas you don't want to waste?...
    AR15xAR10, Mush Mouse and shakerhood like this.
  7. Oct 30, 2016 at 11:14 AM
    Larzzzz
    Larry
    MA
    It's got stabil, but it is a couple months old...
  8. Oct 30, 2016 at 11:56 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    :goingcrazy:Don't put that crap in your truck. Who knows what it will do to the plugs, the O2 sensors, the computer that controls spark and mixture may freak out. Just burn it in whatever you originally had it for.
    AR15xAR10 and Mush Mouse like this.
  9. Oct 30, 2016 at 12:00 PM
    Gofocoffee
    Gofocoffee Member
    2012 TRD sport DC
    I dumped about 4L (1gal) into my truck last year and nothing bad came of it. Of course that being said it was my old ford ranger not my new tacoma!
  10. Oct 30, 2016 at 12:06 PM
    SoCalSteve
    SoCalSteve Sunshine Tax
    San Diego
    2017 F150 XLT
    I wouldn't do it. $20 worth of fuel isn't worth risking on a $20,000 truck.
    Mush Mouse likes this.
  11. Oct 30, 2016 at 12:20 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Been doing that for decades now, never had an issue due to the extreme dilution and the fact that 2 stroke oil is formulated to be low ash and designed to be burned. I don't know if I'd do it with a DI type FI system but port type, I doubt it would ever be an issue. Doubt if it'll affect the o2 sensors or Cats either as vehicles can burn quarts of oil between changes and not have an issue and that is not oil designed to be combusted. [many new vehicle manufacturers consider a quart of oil for every 1000 or so miles to be perfectly acceptable.]
    Old_Skool likes this.
  12. Oct 30, 2016 at 12:24 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Just put it in the wife's car. It will burn just fine, don't ask me how I know...
    AJH387, FFBlack, TacomaMike37 and 3 others like this.
  13. Oct 30, 2016 at 12:29 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    OP, you don't have a boat or a friend with a boat up there?
    As far as burning it in the truck, I would do it. Maybe a little bit less than what you plan, but either way no hesitation from where I sit. Of course, I used to dump my unused gas in my Cummins Dodges or unused MOGAS in HMMWVs or unused diesel in gas generators.
  14. Oct 30, 2016 at 12:42 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    You'll add contamination to your cats and might damage the sensors. It's not worth it. If you have an old carbureted rig laying around it's actually fairly good for the engine in small enough doses.
    ZachMX likes this.
  15. Oct 30, 2016 at 1:36 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    no problem adding some to a full tank... have done it many times over the years.
  16. Oct 30, 2016 at 2:25 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    This.
  17. Oct 30, 2016 at 2:42 PM
    DrVonEvilSatan
    Toyota Truck
    Modern 4 stroke oil has been designed to be burned in small amounts. Additives that existed in the past are no longer used because burning them fowls emissions equipment. Take ZDDP for example. This two stroke oil hasn't been certified to be ran in a 4 stroke engine and I wouldn't bet my expense cats on it.
    ZachMX likes this.
  18. Oct 30, 2016 at 2:56 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  19. Oct 30, 2016 at 2:58 PM
    Mush Mouse
    mush
    2013 SR5
    put it in my weedwhacker
  20. Oct 30, 2016 at 3:12 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I slop all my old fluids at work.
    It's a fringe benefit of working at a refinery. Easy peasy recycling.
