What do you do with your ipod cables?
Discussion in 'Audio & Video' started by motoxmann, Sep 11, 2010.
  1. Sep 11, 2010 at 1:54 AM
    motoxmann
    motoxmann [OP] Well-Known Member
    Bay Area
    2009 TRD Sport
    Fox 2.5 RR coilovers, Fox 2.0 piggyback rear, toytec aal, TC UCA's, weathertec liners, Wet Okoles, grillcraft in the mail
    So I'm installing my new kenwood single din on monday and it comes with an iPod hookup. I've seen people run the ipod cable to the glove box then just control it from the head unit, but I'm gonna be using my iPhone so putting it in the glove box isn't practical. How's everyone routing their cables so that they're accessible but tucked away and not just laying around.
  2. Sep 11, 2010 at 1:59 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Run the wire behind your steering wheel column and have the cord come through that little storage space by your left knee....Nicely tucked away and out of sight/out of mind :D
  3. Sep 11, 2010 at 2:47 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    not a bad idea coltsTRD...
  4. Sep 11, 2010 at 4:36 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I ran my cables underneath the center console. I cut a hole in the bottom of the console for the cable to come up into the center console. My ipod sits in my center console.
  5. Sep 11, 2010 at 10:20 AM
    motoxmann
    Bay Area
    2009 TRD Sport
    That might work. Got any pics?
  6. Sep 11, 2010 at 11:01 AM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Center console was the easiest for me and I can tuck my iPod away behind the little net.
  7. Sep 11, 2010 at 11:23 AM
    Janster
    Jandy
    Lancaster, PA
    I'm at work now till midnight so I can't get a pict.
    It's pretty easy. Just route the cable under the side of the console and put a hole in the bottom of the console and route it thru the hole. If I remember, there's a piece of felt at the bottom of the console. YOu just pick that out and there's bolts to remove the console.
  8. Sep 11, 2010 at 1:52 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i have mine running through the little cubby next to your right knee, i have all of the cords tucked in behind the headunit
  9. Sep 11, 2010 at 2:02 PM
    TAKoma907
    TAKoma907 Well-Known Member
    Charles
    Alaska
    06 Tacoma
    2.5" Lift, Bilstein shocks, 10" Sub, CCFL Halo Headlights, K and N Air Intake, MagnaFlow Exhaust
    x2
  10. Sep 11, 2010 at 7:57 PM
    DevL
    DevL Well-Known Member
    Why not just run it to the glove box? Bluetooth the phone and run the music and video off the headunit?
  11. Sep 12, 2010 at 1:44 AM
    motoxmann
    Bay Area
    2009 TRD Sport
    Thanks for the suggestions guys. I could run it to the glove box but that would just be a pain in the ass to plug in every time I wanted to listen to music off the phone or plug it in to charge it. I'll probably try to run it to the center console.
  12. Sep 13, 2010 at 6:41 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i went to the center console. busted off the lower front tab that holds the little cargo net and ran the ipod cable in thru that. than sold the cargo net. i aslo have an auxillary wire that i can hook up my evo to, or any other thing else that uses a 3.5mm jack.
  13. Sep 13, 2010 at 6:59 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    X2, I have not run mine yet, but this is where I am going to run it. Then you can keep your phone in the holder.
  14. Sep 13, 2010 at 7:17 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    in small cubbyhole to lower right of steering column...works great and keeps it out of sight.
  15. Sep 14, 2010 at 7:40 AM
    81shark
    oh, you silly automatic people. :)
  16. Sep 14, 2010 at 7:43 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I was thinking the same thing :D I don't have that compartment thing.
    My ipod stays in my glove box most of the time. Out of site out of mind for thieves.
