What do you guys think on 0-w30 mobile one oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chrisd540, Dec 27, 2009.
  1. Dec 27, 2009 at 3:55 PM
    chrisd540
    chrisd540 [OP] Member
    Northern Colo
    09 White TRD Sport
    Anthracite FJ TRD wheels, N-fab nerf bars, Bed mat
    Well about that time again oil change. With all this talk about fuel milage and oil polls has or is anyone using mobile one 0-w30. It says on the bottle meets or exceeds Toyota standards for 5-w30. And also a 2% increase in fuel economy. I know 2% is not much what what do you think?
  2. Dec 27, 2009 at 4:14 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    Welcome first off. :wave:
    I too have wondered about this oil.??????
    So I just went ahead and put it in my last oil change last weekend...:eek:
    I have not driven enough to check my mileage yet, so as for the savings???? I'll have to see.
    I'll be watching this thread as to what others say, but from what I read else where it should be OK.
    Yuma Taco,
  3. Dec 27, 2009 at 5:37 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I will be using it next change!!
  4. Dec 27, 2009 at 5:46 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I'll be sticking to Toyota's recommended engine oil weights.
  5. Dec 27, 2009 at 6:01 PM
    Rhino8541
    Rhino8541 I like ze best!
    AZ
    2017 QS DCSB OR
    I put this oil in about 1000 miles ago. So far no issues. Engine MIGHT be quieter, but haven't noticed any substantial increases or changes in mileage. I like it though.
  6. Dec 27, 2009 at 6:19 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    doesnt the 30 weight make it heavier therefore if anything decrease mileage somewhat?
  7. Dec 27, 2009 at 6:31 PM
    Rhino8541
    AZ
    2017 QS DCSB OR
  8. Dec 27, 2009 at 6:32 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    i don't think it'd make any bit of difference. the 0 refers to the weight of oil when cold. it will flow better/quicker in cold temps but as soon as the engine is up to operating temp the oil will be at the regular recommended 30 weight.
  9. Dec 27, 2009 at 6:51 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    I've used the M1 0w-30 since my first oil change @ 5k. Seems to be working just fine, I'm about to do my 15k change this week with 0w-30. I don't think that you'll see any kind of noticeable increase in fuel economy, but I like it because it flows well on cold starts.
  10. Dec 27, 2009 at 6:52 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    :thumbsup: how long does it take for your truck to start to warm up? that is the only time that it will actually matter... (hint, not much at all!!)
    but being from northern colorado, it might make a slight difference for you. here in sunny socal, it wont matter...my coldest starts are in the 45*F range!!
  11. Dec 27, 2009 at 6:54 PM
    MassTaco
    Massachusetts
    V6 4x4 SR5 DC AT5
    In socal I wouldn't think it would take too long to warm up, but I can tell you here in Mass when it's 9 degrees F in the morning, it's a full 7 miles before my temp gauge is at normal operating range.
  12. Dec 27, 2009 at 6:57 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    right, but once the engine starts to warm up, the oil is already plenty hot and no longer taking advantage of the 0 weight viscosity.
  13. Dec 27, 2009 at 7:26 PM
    MassTaco
    Massachusetts
    V6 4x4 SR5 DC AT5
    To your point, it's probably only the first 15 seconds or less that it really matters, but there doesn't seem to be a downside to the 0w-XX vs. 5w-XX. The HT/HS rating is even fairly good for the Mobil 1 0w-30 (HT/HS of 2.9). Where I buy oil the M1 0w-30 and 5w-30 cost the same, so even if the 0w has only a slight advantage in cold flow, it's still an advantage.
  14. Dec 27, 2009 at 9:12 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Engine oil takes around 5 - 10 minutes of driving to achieve normal operating temp. The flow and friction advantage lasts for approximately that amount of time on a cold start, with no drawback. There is no disadvantage to this particular 0W oil. It is probably the best protection, best mileage oil that you can buy for the Tacoma. Also if you happen to live somewhere that has a harsh winter, you would definitely be increasing the longevity of your engine by using this oil.
