What do you keep yout PSI at?
Discussion in 'Wheels & Tires' started by OCTaco, Apr 5, 2010.
  1. Apr 5, 2010 at 4:51 PM
    OCTaco
    OCTaco [OP] Well-Known Member
    OC
    '16 TRD Sport DCSB
    What do you keep your PSI at? Mine are at 45 right now but usually i keep them at 40. Is this too much?
    Ive got AT 265/75/17
  2. Apr 5, 2010 at 4:53 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    33-34 in my AT....what kind of tires do you have?
    edit: tires are 265/75 AT
  3. Apr 5, 2010 at 4:53 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    29-31.....................depends on tires as well.....................
  4. Apr 5, 2010 at 4:57 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Ive got all terrain 265/75/17
  5. Apr 5, 2010 at 5:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Chalk Line Test- 100% of the time it works pretty damn well.
    Search it cause I don't really feel like typing it out again...
  6. Apr 5, 2010 at 5:08 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    32 psi with stock tires. Even tire wear after 17,000 miles and 5,000 mile rotations.
  7. Apr 5, 2010 at 5:17 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    It will vary. Do the chalk line test.
  8. Apr 5, 2010 at 5:19 PM
    P-Hill Tacoma
    P-Hill Tacoma Well-Known Member
    Missouri
    2010 DC Short Bed 4WD Off Road Barcelona Red
    Fr Bilsteins@1.75", Rr Bilsteins w/ 1.5" AAL & RideRite Airbags, Truxedo Lo-Pro Tonneau, Step Tubes, 1.25" Spidertrax
    35 before lift. 29 both ends after lift.
  9. Apr 5, 2010 at 5:31 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    265/75/16 Load range C= 42psi works for me.
  10. Apr 5, 2010 at 5:34 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    33-35. 40 and up your tires are probably going to wear way faster than you'd like! :eek:
    285/75/16 KM2s
  11. Apr 5, 2010 at 5:41 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    My tires call for a max of 65psi. I run 56-58 in front and 54-56 in rear. I have BFG AT 285/70/17
  12. Apr 5, 2010 at 6:36 PM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    "The 'Chalk Line Test': Draw a heavy chalk line across all the tread faces. drive slowly forward in a straight line for a few revolutions of the tire. Get out and observe the wear pattern of the chalk. If it has worn away evenly, then the inflation is correct. If either the edge or center of the line is worn first, then the tire is under or over inflated, respectively." from 4crawler site.
  13. Apr 5, 2010 at 6:40 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Never over 35psi. Usually keep them around 30-32.
  14. Apr 5, 2010 at 6:42 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i keep my 265.75.16 at 40
  15. Apr 5, 2010 at 6:44 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Street driving, 32 PSI at all four corners in roughly 60 degree weather. Offroad I air down to the situation.
    PSI will vary about 1 PSI per 10 degrees of temperature change...also, on a sunny day you'll gain a couple as well. This is why it's important to watch your tire pressure as seasons change.
  16. Apr 5, 2010 at 10:26 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    The reason i ask is because my ride is really bumpy. I was hoping that by kicking the PSI down to 34-36 it would ease the bumpiness a bit. i dont wanna kill my MPG though.
  17. Apr 5, 2010 at 11:04 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I get about 18 MPGs with my 285/75/16 KM2s at ~34 PSI. You just need to drive slow. ;)
    The tires soak up a lot of bumps. :D
