What do you make of this?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoguy, Nov 18, 2009.
  1. Nov 18, 2009 at 5:12 PM
    Tacoguy
    Tacoguy [OP] Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    I'm at my witts end as far as MPG is concerned. My MPG has dropped from 18-19 to about 15-16. Now this tank seems to be even worse.
    Recent maintenance:
    -Iridium Plugs 8k miles ago
    -Cleaned KN Filter
    -Replaced Fuel filter 500 miles ago
    -Constantly use Lucas injector cleaner
    -Also used Gumont Regane this last fill up
    -Tried cleaning MAF, However stripped a screw, so its hard to clean it. :D
    -Seafoamed twice using vacuum line
    -Been using Royal Purple synthetic for about 10k miles
    -Changed Differential Fluid with Mobil 1 synthetic
    -Also reset ECU
    Now, today I noticed one more thing. Once I started the engine for about a minute and turned it off, I noticed a gasoline smell coming from the exhaust.
    Could that be a bad O2 sensor? Or just winter gas?
  2. Nov 18, 2009 at 5:20 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    FIrst, I would recommend not using those injector cleaners and off the shelf additives. Second, It sounds as though you may have an O2 going. I would also suggest going to Denso Dual grounds vs the Iridiums.
  3. Nov 18, 2009 at 5:25 PM
    Tacoguy
    Alex
    Chicago
    I too thought of going to Denso Dual Grounds, however I hate to think I wasted so much money on Iridiums for nothing. Only 8k miles used.
    I really do not think that Lucas Upper Cylinder Lubricant is all that bad. A lot of people use them and it works. I also use it all the time in my corolla, and it is just fine.
    As far as the O2 is concerned, I thought that if it was bad I would get a check engine light?
  4. Nov 18, 2009 at 5:27 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  5. Nov 18, 2009 at 5:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely sounds like an o2 sensor is heading out on ya. you will get a cel, but only when the sensor isnt functioning.
  6. Nov 18, 2009 at 5:28 PM
    Tacoguy
    Alex
    Chicago
    Forgot to mention that I seafoamed twice. LOL
    Both times through the vacuum line.
  7. Nov 18, 2009 at 5:28 PM
    riggsjt
    riggsjt Well-Known Member
    Jake
    Meridian,MS
    11 FJ Cruiser
    Seafoam does work on everything
  8. Nov 18, 2009 at 5:34 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Not always in regards to the O2.
    To be honest, how can you tell the difference with the Lucas?
  9. Nov 18, 2009 at 5:37 PM
    Tacoguy
    Alex
    Chicago
    I really can't but I know a lot of people who swear by it. I am kind of a sucker like that. lol
  10. Nov 18, 2009 at 5:43 PM
    Tacoguy
    Alex
    Chicago
    Well since it is sounding like an O2 Sensor, has anyone had to replace theirs yet?
  11. Nov 18, 2009 at 5:49 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Lots of people have. Myself included on my 98
  12. Nov 18, 2009 at 5:52 PM
    Tacoguy
    Alex
    Chicago
    My truck has 53,000 miles. Does that seem a little soon for an o2 sensor?
    Also where did you get your o2 sensor and how much was it?
  13. Nov 18, 2009 at 5:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    replaced my bank 1 sensor 1(upstream) a few weeks back. not hard at all. the clip is the biggest bitch about it.
  14. Nov 18, 2009 at 5:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    my truck only had right at 60k.
    got my sensor from the stealership.....right about $215 or so.
    rockauto.com has the alot cheaper.
  15. Nov 18, 2009 at 6:00 PM
    Tacoguy
    Alex
    Chicago
    Damn, that is quite a bit. However this bad gas mileage is driving me crazy. I suppose I should test the older one before I replace it.
    Most likely, would the bad sensor be the upstream one?
  16. Nov 18, 2009 at 6:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats the one that goes most often i believe.
  17. Nov 18, 2009 at 6:06 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  18. Nov 18, 2009 at 6:42 PM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    The primary/upstream is the one that controls fuel mix, the secondary has nothing to do with fuel, it just makes sure the cat is working OK.
    O2 sensors have a life span, they wear out like anything else. I replace mine based on mileage, around 80 to 100000 miles, but they can fail earlier
  19. Nov 18, 2009 at 8:45 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Just did mine at 110K and got it at RockAuto.com for a descent price.
    its perty easy to do, its just that stupid little clip that a bitch to get to and up plug.
    I will be checking my MPG's soon.
  20. Nov 18, 2009 at 8:46 PM
    ETaco23
    Evan
    PNW
    So should we be replacing the Bank2 sensor as well? the one for the cat.
