What do you run for psi in Winter/Summer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smuggiesrider, Feb 8, 2010.
  1. Feb 8, 2010 at 11:38 PM
    smuggiesrider
    smuggiesrider [OP] Well-Known Member
    CR
    Vermont
    Silver 10 Trd Sport DC 6spd
    Satoshi grille, ARE cap, Rubber Bed mat, TRD Quick-shifter, N-Fab step rails, Wet Okoles seat covers, Husky Floor Mats, Stubby antenna, AFE Pro dry Filter, Thule rack w/ Cargo box, Sportz SUV Tent, Custom fit Air Mattress for Bed, TRD cat-back exhaust, de-badged and Sockmonkey'd. Hella Black Magic 500s, Toytec ULK, Dakar OME leafs, LR Uca's.
    I Know different tires require different psi and the new Tacos have the fancy TPMS. BUT my Stock 17in Tires say max 44psi and the door says 29. I drove off the lot and switched to 16in tires and steel rims and kept the 29psi. The max on these are also 44psi.
    Bottom line my MPG SUCKS. 15mpg, 12.8mpg, 13.4mpg. The last 3 fill-ups!
    I also know my 6spd Tow package manual is the worst rating w/15-18.
    Any suggestions to help me squeeze some more mpg. Oh by the way I'm using 89 octane, mainly shell, sometimes mobil and citgo. I'm at 2200 miles and want to change to Mobil 1 soon then go 5k.
    Yes?
    What does everyone run for psi?
  2. Feb 9, 2010 at 5:28 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    I run 30 psi in both my 17s in summer and winter 16's. You can run a couple more PSI in your winter tires (many manuals recommend), but if you put too much, the center line will wear much quicker. I found this out running my Blizzaks 35 psi for 2 winters...
    As for mpg w/ the 6spd. I get 17-18 all winter, though mostly hilly rural driving. Using 89 gas, full syn oils, but the main thing is keep her between 1500-2000 rpm cruising. On the hwy, once your over 65, mpg plummets. Your truck is also new, so w/ time mpg will improve. Your call if you want to switch the oil now.
  3. Feb 9, 2010 at 6:27 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    i run 28 psi winter on my winter tires (29psi on door sticker btw) and run 38-44 (51 psi max on sidewall) on my stock at20s.
    That high of a psi has never shown a discernable amount of wear in the center on my previous trucks or tires in the load range"C" range over 30-40k.
    22-23pmg winter 24-26 summer mpg fwiw.
  4. Feb 9, 2010 at 6:41 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Not sure about the 4.0L....but I have the little brother and I noticed an increase in MPG after 5K...and it has slowly been improving since (6200 miles now). There seems to be more that you can do with the V6 than the 4-banger to increase MPG....but with the manual transmission, it's tough to do that up there with nearly no flat driving. (I grew up in VT).
    Winter mileage will suck because: 1. Winter gas is not as efficient. 2. Driving habits are different.....you probably use the transmission more for slowing down than in warm weather/dry roads. 3. You may use 4WD more.
    Check out some of the other threads for increasing MPG for a V6....synthetic oil, different air intake, driving habits/modes, and others.
    Good luck!
  5. Feb 9, 2010 at 7:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've been running about 32psi. Lately, that my tires are getting thin ....I've put it back down to 29psi and that's only to maybe gain a little more traction in the wet/snowy stuff. When I get new tires, I'll be back up at 32 again.
  6. Feb 9, 2010 at 12:40 PM
    smuggiesrider
    CR
    Vermont
    Thanks for all the advice! I will continue to run 29 i guess and see if it improves with time/ season change. Tough part is I'll be towing a boat a lot in the summer so that won't help. Maybe I'll run a tank at 30 then 31psi to see if there is any difference. Thing is I feel like I have great traction with 29. We'll see.
