What do you think about a prerunner in the sand???
Discussion in 'Off-Roading & Trails' started by DLR07, May 13, 2010.
  1. May 13, 2010 at 4:23 PM
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    I've had no problems. Common sense goes a long way. I've only gotten stuck 2x. Both times trying to pull other people out. The best advice is do not dig your self into a hole. I only needed a push to get moving again.
    Have fun.
  2. May 13, 2010 at 4:49 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Invest in a good tire that can handle the sand as well. I have 4x4 and have only used it a handful of times. Never needed it on the beach though. Locking diffs work pretty well but to be safe, it would be a good idea to have somebody else with you the first few times to pull you out. Getting stuck in the sand is eventually inevitable. Even for us 4x4 owners.
  3. May 13, 2010 at 4:51 PM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    very true!
  4. May 13, 2010 at 4:55 PM
    bagster
    bagster Well-Known Member
    If you can hit the beach right after a rain, the sand will be packed and make
    driving easier. Ditto with driving next to the water during low tide.
  5. May 13, 2010 at 5:04 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I go down between 10-12 in the rear and 12-15 in the front.
  6. May 13, 2010 at 6:37 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Bed mat huh??? Never thought of that. I would think that would be a little bulky to get under your tires, esp. if you needed to dig a bit. I did see some foldable ramp like contraption that were close to the width of a tire, and could be placed fairly easily behind the tire if getting buried. Come to think of it, I'm gonna try and find them again.
  7. May 13, 2010 at 6:42 PM
    raycie
    Oahu, HI
    In need of $$$
    Something like "save-a-tow"
  8. May 13, 2010 at 7:22 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    It can be a big help, no doubt about it. I've dug a friend or two out with mine.
    The bed mat is a great idea. I've seen one used for that very purpose before.
  9. May 13, 2010 at 8:06 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    There always has to be one. BTW I had a 4Runner for 11 years and only used the 4 wheel drive while off-roading a couple of times.
    Besides without prerunners to pull out of the sand you wouldn't really have any need for your 4x4.:D
  10. May 13, 2010 at 10:51 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Best advice yet... ^
    I (in 4WD, before TRAC) would run at 15 psi, but if that still didn't float (sand conditions change) or if I had 3 ply sidewall mud tires, drop it to 10 psi... get yourself out without a bed mat or a pull. Mexicans in Baja use 2WD on the beaches all the time to get their nets and boats... bald tires and low low pressure on all 4 tires... in 2WD. Aggressive mud tires are terrible, and light tread are best...The Rugged Trails work fine in the sand at 15 psi.
    The new '10 Tacoma with TRAC in H4 didn't need any air removed from the tires... a first on the Baja beach south of San Felipe!
  11. May 13, 2010 at 11:02 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Keep moving don't stop. if you do don't feather the gas or it will dig in. Even with Tires made for sand it will dig. Also this was wet sand.
  12. May 13, 2010 at 11:02 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    What about the Rear Locker?
    Would it help get to the packed sand??
  13. May 13, 2010 at 11:04 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    I was locked when I did that lol
  14. May 13, 2010 at 11:15 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
  15. May 13, 2010 at 11:25 PM
    #35
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Just keep a steady foot. It was my own fault, I was going too slow and tried to speed up and it dug in and I threw it in reverse and went forward and when it went forward it went bumper to the sand.
  16. May 13, 2010 at 11:29 PM
    #36
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Dont stop and ggod luck! Bring a 4x4 with!
  17. May 13, 2010 at 11:30 PM
    #37
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I haven't got stuck in the sand yet....knock on wood lol
  18. May 13, 2010 at 11:33 PM
    #38
    MOT
    Daniel
    Las Vegas
    because the sandbox in your back yard is only 5 feet by 5 feet haha!:D
  19. May 13, 2010 at 11:41 PM
    #39
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    I got stuck at the clean up when we were in the wash at butcher jones. from the time i got stuck to when I was out was about 1 min. Derek backed up and pulled me out and we kept going. That was my first time in the sand.
  20. May 14, 2010 at 1:04 AM
    #40
    ColtsTRD
    Scott
    AZ
    :laugh:
    :anonymous:
