What do you think about that? DTRL Leds with BHLM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Apr 7, 2013.
  1. Apr 9, 2013 at 6:16 PM
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    08 TRD Sport DCSB Prerunner
    Bilstein 5100s on all 4 corners. Fronts set @ 2.5". 1" block in rear with 1000 lb SumoSprings. BFG KO2- 265/70/17.
    I have the same problem with the painted reflectors. I'm thinking about taking the headlights apart and spraying the reflector with chrome spray paint to get more brightness from the LED.
  2. Apr 10, 2013 at 12:43 AM
    bra
    bra [OP] Well-Known Member
    2008 TRD sport access cab
    Smoked headlights with White DTRL, Michelin
    Black reflector + Chrome paint onto it = A less visibility, isn't it? Don't you think there is a way to change the reflector? Can we buy only the reflector? Or BREAK it, so no need to take out the cover with the oven :mad:
  3. Apr 10, 2013 at 1:09 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    No. Not if you are thinking what I'm thinking.
    -Take apart the headlight
    -Remove signal light lens
    -Sand backside of signal light lens with fine paper
    This will make the lens diffuse the focused light beam of the LEDs, making the entire square of the lens look lit.
  4. Apr 10, 2013 at 1:47 AM
    bra
    OH yes,
  5. Apr 10, 2013 at 1:48 AM
    bra
    I will try that. I hope to find a oven which fits my headlight. Mine are small
  6. Apr 11, 2013 at 11:27 AM
    wade9986
    Ross
    Stuart, Florida
    Problem solved. Just ordered some Anzo headlights.
  7. Apr 11, 2013 at 11:33 AM
    Large
    Large Red
  8. Apr 11, 2013 at 11:35 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    Silver 2010 DCSB 6-speed supercharged
    Looks like it's pnp from the quote on the website.
  9. Apr 12, 2013 at 9:01 PM
    bra
    Let's see the results when you install it
  10. Apr 12, 2013 at 9:03 PM
    bra
    I plan to sand it without taking apart the headlight, just by the bulb's hole behind the headlight (don't have an oven which fits)
  11. Apr 14, 2013 at 4:21 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    06 Double-Cab TRD Sport 6-Speed
    When I did my BHLM I had the same idea. I made sure I didn't paint the reflective part of the turn signal and pulled out the amber lens. My truck does not have DTRL but I figured if it did, it would be interesting to have the turn signals look like a second set of headlights within the headlights.
    I ran clear halogen turn signal bulbs for a while, but switched them back when I realized how overly bright my turn signals had become.
    Keeping the reflectiveness also helps with the lighting of the Whelen Vertex I have mounted.
    Too bad I ruined the inside with a power washer. Fixed that with some silicone though.
  12. Apr 14, 2013 at 4:57 PM
    Hoozel
    Hoozel Well-Known Member
    Ty
    Edmonton AB
  13. Apr 14, 2013 at 5:09 PM
    bra
    It is not bad? Do you have a pic with the entire look of the front of the truck?
    Here is mine, what do ya think?
  14. May 21, 2013 at 7:22 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Any update on this? That looks like a great mod, but I'm curious about how the install goes, light output, especially how the light bulb ring you have to order since the LED is universal.
  15. May 22, 2013 at 9:12 AM
    #35
    Hoozel
    Ty
    Edmonton AB
    It finally shipped. Should be here any day. Was back ordered forever.
  16. May 30, 2013 at 8:44 AM
    #36
    Agent Smith
    Did you get and install yet?
  17. May 31, 2013 at 8:18 PM
    #37
    Skeeter Skeetin
    Skeeter Skeetin Well-Known Member
    Greg
    Coos Bay, OR
    MGM 4x4 V6 6 speed
    5100's all around w/ 1.75" front. 1.5" Toytec AAL ARE shell with roof rack. Weathertech vent-visors and floormats 20% tint on front. Black and charcol wet okole's VLED V3 Triton DTRL's/turn signals. ECGS bushing
    Going on a old post but i figured i'd add since i have the VLEDs in my truck. The install is really easy. you just have to find a place to mount the control box. For the bulb, it comes with a bunch of different screws and washers, you just have to find the combo that works for you. You can also tap into your headlight power to dim the leds to 50% when your lights are on, just like the DTRL's do. Light output is awesome, and customer service is great.
  18. May 31, 2013 at 9:11 PM
    #38
    Rodallg
    Rodallg Well-Known Member
    CA
    I like the look, can you give me the link for the lights that you ordered along with the one for the LED mod?
    Thanks
  19. May 31, 2013 at 9:49 PM
    #39
    bra
  20. May 31, 2013 at 9:54 PM
    #40
    Rodallg
    CA
