What do you think of this setup?
Discussion in 'Suspension' started by Tacoma414, Jun 15, 2011.
  1. Jun 15, 2011 at 4:18 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
  2. Jun 15, 2011 at 4:22 PM
    Gieser
    Gieser Official Flatlander
    MB, Canada
    06 tundra yamaha edition
    scion Head Unit and magnaflow muffler...so far
    the spring you wont need if your going with that coilover kit. and the rear shocks you'll need but also an add a leaf or blocks.
    hope this helps
  3. Jun 15, 2011 at 4:23 PM
    Tacoma414
    Cody
    Agua Dulce
    that helps a lot, ill save the $180 and whats better, blocks or leafs? i wanted to keep the back stock for the pre runner lean
  4. Jun 15, 2011 at 4:27 PM
    Gieser
    MB, Canada
    if you want the lean you wont need anything. im not a fan of the "bro" lean but its your choice. an AAL would be better and a new leaf pack is the best option but not chaep. i think an aal is under $100.
  5. Jun 15, 2011 at 4:30 PM
    Tacoma414
    Cody
    Agua Dulce
    will the shocks in the back help the ride? cause i plan to do some off roading but not to much, just coil overs that can take braking bumps but im not going over 4' whoops or anything crazy, just pot holes and bumps
  6. Jun 15, 2011 at 5:04 PM
    Gieser
    MB, Canada
    on a first gen id say yes since they wear out over time but for a second gen im not sure. i think it would, hopefully a second genner will chime in...
  7. Jun 15, 2011 at 6:06 PM
    Tacoma414
    Cody
    Agua Dulce
    Yeah so the shocks wouldn't lift the back, thats why I need the AAL?
  8. Jun 15, 2011 at 6:14 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    No, shocks do not add lift. An add a leaf/blocks/shackles are needed to lift the rear. You need new extended length shocks when you lift the rear.
  9. Jun 15, 2011 at 6:18 PM
    Tacoma414
    Cody
    Agua Dulce
    Oh ok, well if I replace them will they help the ride in the rear?
  10. Jun 15, 2011 at 6:20 PM
    kmok
    Kyle
    Columbus, Ohio
    Yep, if you're not going to lift the rear aftermarket stock length shocks will work
  11. Jun 15, 2011 at 6:23 PM
    Tacoma414
    Cody
    Agua Dulce
    If I get longer shocks do I have to cut the bed and run it through?
  12. Jun 15, 2011 at 6:28 PM
    kmok
    Kyle
    Columbus, Ohio
    You won't have to cut through the bed to run longer shocks unless you go with some sort of long travel setup.
  13. Jun 15, 2011 at 6:31 PM
    Tacoma414
    Cody
    Agua Dulce
    Alright that helps, any shocks you Reccomend? That aren't to pricy for the back
  14. Jun 15, 2011 at 6:34 PM
    kmok
    Kyle
    Columbus, Ohio
    A lot of people run the bilstein 5100s and really like them. I'm running the 5100s with my new leaf pack and I really like them. You should try calling the guys at Toytec or Down South Motorsports and talk to them about what shocks to run in the rear so you can get the right length shocks.
  15. Jun 15, 2011 at 6:36 PM
    kmok
    Kyle
    Columbus, Ohio
    Actually these will work. It says it works with 0-3" of lift so if you decide to lift the rear in the future these shocks will work too.
  16. Jun 15, 2011 at 6:36 PM
    Tacoma414
    Cody
    Agua Dulce
    Yeah I'll give them a call, I really like toytec so I'll ask them
  17. Jun 15, 2011 at 6:41 PM
    kmok
    Kyle
    Columbus, Ohio
    Sounds good. I ordered my lift from them and they had great customer service, I'll definitely buy from them again :thumbsup:
  18. Jun 15, 2011 at 6:44 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Your on the right track bud...those adjustable coil overs and 5100s would be great up front and then a 1.5" AAL for the rear and some rear 5100s as well...remember that if you go higher than 2.5", new UCAs are recommended for alignment purposes
  19. Jun 15, 2011 at 7:43 PM
    Tacoma414
    Cody
    Agua Dulce
    Yeah I'm staying at 2.5 cause of that reason, but once I get money I'll get the UCAs, this helps a lot
