What do you think?
Discussion in 'Suspension' started by mrlooney88, Aug 6, 2011.
  1. Aug 6, 2011 at 6:12 PM
    mrlooney88
    mrlooney88 [OP] Well-Known Member
    Ohio
    '10 d/c sr5 4x4
    Hello all. I have a question for all of you that know a whole lot more about this stuff than I do. I have eibach springs with billies set to zero up front and have 1.5 AAL and billies in the rear. My question is if I was to get the TSB done on the rear would I be level, nose high or a big rake. The rear is going to be TSB only. I have about a 2" rake now the way it is set up. Thanks in advance for any and all advise.
  2. Aug 6, 2011 at 6:15 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    So you would have 2.5" of total lift in the rear, and 1.6 of total lift in the front...sounds like you would have 1" more rake than a stock Tacoma.
  3. Aug 6, 2011 at 7:03 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    What I want to know is if the eibachs and billies at zero and the TSB alone would make me level or have a bigger than normal rake?
  4. Aug 6, 2011 at 7:04 PM
    TexasTacoma37
    Tsb=1"
    Eibachs=1.6"
    Therefore you will have less rake than stock.
  5. Aug 6, 2011 at 7:38 PM
    mrlooney88
    Ohio
    '10 d/c sr5 4x4
    So the TSB is about an inch higher than the non TSB springs?
  6. Aug 6, 2011 at 7:39 PM
    TexasTacoma37
    Yep, after settling.
  7. Aug 6, 2011 at 7:47 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    KPT is the man...that is all!
  8. Aug 6, 2011 at 8:05 PM
    TexasTacoma37
    No YOU da man scotty
