What do you tow with your 4cyl?
Discussion in '4 Cylinder' started by ToyotaFamilyof6, Jan 16, 2016.
  1. Aug 27, 2016 at 3:19 PM
    rodehard
    rodehard Active Member
    BKP
    2001 Tacoma Base
    K&N Intake. Gutted Cats. Slightly larger tires.
    Hauled a double axle dove tail 8x16ft car trailer with the car on it. 5500lbs was what I towed over 150 miles. Did it just fine. Slow, but fine.
  2. Oct 30, 2018 at 1:31 PM
    Badrock
    Badrock Member
    Base 2014 acess. Charcole grey
    What does thy he trailer weigh
    Blais03 likes this.
  3. Oct 30, 2018 at 1:35 PM
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    My Starcraft camper. I think it’s 2,300 lbs. pulls great.
    AxisCab and Badrock like this.
  4. Oct 30, 2018 at 1:38 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    I have 4.88s so towing was a little easier, but I've towed in the 2000lb mark. Not sure of the exact weight. Having a manual helps.
  5. Oct 30, 2018 at 8:08 PM
    reloader403
    reloader403 Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    Sorry for the late reply, but that trailer weighed 2980 with out water or gear. That 4cyl pulled it just fine with that manual trans. Won't win a land race but very manageable and fun!
    Badrock[QUOTED] likes this.
  6. Oct 31, 2018 at 4:49 AM
    OilTruck
    OilTruck Well-Known Member
    Peter
    Katy, TX
    2016 SR Stick 4x4 Access Utility
    Anyone know what all is included in the tow package? I have a 2016 utility package SR and would like to make it "properly equipped".
    Misfit likes this.
  7. Nov 2, 2018 at 9:26 AM
    Misfit
    Misfit Well-Known Member
    IL
    2017 SR 2.7L 4x4 5MT
    Normally a tow package adds more engine cooling, trans cooler, oil cooler?, wiring and hitch.
    Since you have a 2.7 MT, there isn't much you really need. It has plenty capable cooling.
    Per my manual which should be the same:
    -Trailer wiring
    -Receiver Hitch
    -Trailer brakes over 1,000lbs
    -Anti-Sway over 2,000lbs
    -3,500 lbs max
    OilTruck[QUOTED] likes this.
  8. Feb 27, 2019 at 6:33 AM
    mr_smoothhhh
    mr_smoothhhh Active Member
    Long Branch, NJ
    2015 taco SR AC 4x4
    I have a hobie 16 too where do you sail? i sail my hobie out of NJ
  9. Feb 27, 2019 at 6:48 AM
    Snoopy48
    Snoopy48 LRM (1943-2017)
    2019 Tacoma SRDC
    I have yet to tow my 4x8 trailer but I will be soon. I am however a little anxious about my trip since this truck can barely pull itself down the road.
    AxisCab likes this.
  10. Feb 27, 2019 at 6:49 AM
    OilTruck
    Peter
    Katy, TX
  11. Feb 27, 2019 at 6:52 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Moving from Oregon to Montana. Have no idea what the weight was but it was all our stuff. Got like 8mpg’s that drive :thumbsup:
  12. Feb 27, 2019 at 7:23 AM
    Snoopy48
    2019 Tacoma SRDC
  13. Mar 13, 2019 at 4:55 AM
    shamuspi
    shamuspi Well-Known Member
    Richard
    2017 Tacoma SR
    None
    My base model 2017 SR (built Oct 17; bought Jan 18) has no trailer nor hitch packages, so it only "hauls" my fat butt.:eek:
    OilTruck likes this.
  14. Apr 1, 2019 at 7:04 AM
    Appalachia Man
    Appalachia Man Well-Known Member
    03 Prerunner X-cab
    2.7L Detroit Truetrac 2" lift OME 880's & Dakar's
    it has towed 16x7 steel trailer with lumber for several construction jobs. pulled 5x10 steel trailer loaded with commercial cabinets and tools from MS to GA, then from GA to KY. no problems pulling SXS on 5x10 trailer or 18' bass boat. i have towed over the rated 3500 a few time. truck had 80k when i bought it and now has 180k. does not use/burn oil and has never had any motor or powertrain issues. run synthetic oil in motor and trans, recently added trans cooler. i also added hellwig helper springs and currently putting the eaton lsd in rear end. this little truck has made me a lot of money, what else is a truck for? big jobs i tow with my silverado... but that's 1 helluva reliable 4 banger in that toyota!
  15. Apr 2, 2019 at 4:19 AM
    #35
    96carboard
    96carboard Well-Known Member
    All that stuff up on your roof, the very large wind barricade made by the stuff in the trailer, and the fact that uhaul trailers tow very badly. I had to rent one of those exact trailers a week ago for an emergency, because my trailers are about 200 km from me and still buried under about 5 feet of ice, and its incredible how much those shitty uhaul trailers drag. It *feels* heavier than my flatbed tandem that weighs at least 3 times as much.
  16. Apr 2, 2019 at 6:16 AM
    #36
    ryfox0276
    Montana
    2013 RC 4x4
    It was not fun, that is for sure.
    For next time we decided to rent a van and tow the truck instead. Probably will be similar in costs as those vans get way better mpg’s towing that kind of weight.
  17. Apr 2, 2019 at 7:41 AM
    #37
    96carboard
    Its a common misconception that a bigger vehicle will get better fuel efficiency towing.
    It comes from a superficial look at the CHANGE in fuel consumption.
    You get a big moving van, and it will get 10 mpg empty, or 9.8 mpg loaded, so the difference is only 0.2 mpg or 2%. Not much, eh?
    Now you get your pickup, and it gets 28 mpg empty, or 14 mpg loaded. That's a difference of 14 mpg or 50%. Seems a huge difference.
    But the important thing to look at isn't the change in fuel consumption, but the ABSOLUTE fuel consumption.
    14 mpg > 9.8 mpg.
    Note: I'm sure that the 8 mpg you quoted is an exaggeration. Either that or you held it in 3rd gear WOT at 90 mph the entire run. I get 22-23 mpg while pulling moderately aerodynamic loads of around 6000-7000 pounds at 80 kph. By moderately aerodynamic, I mean cars or trucks or tractors up on a flatbed.
  18. Dec 1, 2019 at 8:34 AM
    #38
    lnfravor
    lnfravor Active Member
    logan
    2008 2.7L White Tacoma
    3" lift on 31's with bart d trucker wheels
    I pulled two scag mowers on a 24ft trailer. It took longer to break but it didnt slow down to much
    BassAckwards likes this.
