What do you use Dino or synthetic oil???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Feb 15, 2014.
  1. Feb 15, 2014 at 12:43 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Like the title says. what do you guys use on your 1st gen taco Dino or synthetic oil??? Brand??? Let's hear it.
  2. Feb 15, 2014 at 2:38 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    5W30, what ever meets Toyota's specs and is cheapest.
    So far, that has been standard dino oil. Over 200k on my 3.4, and doesn't burn a drop, and starts at -27 F.
    I have 2 other cars that require 0W30, and they get synthetic, because that is the only way you can get 0W30.
  3. Feb 15, 2014 at 2:41 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Mobil 1 Synthetic. You said tittle. :devil:
  4. Feb 15, 2014 at 5:19 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    mobil 1, valvoline, whatever synthetic is on sale at the parts store… also a can of bg moa
  5. Feb 15, 2014 at 5:29 PM
    yoterdude
    yoterdude Well-Known Member
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Aero Turbine 2525, Aero tip, AFE Dry Pro S filter, deckplate mod, TRS Morimoto Mini H1 projectors, TRS xBLed angel eyes, Vent visors, Blacked out tail lights, LED turn signals, 10w LED auxiliary reverse lights, 20in LED light bar, OTRATTW switches, LED interior lights, Blue needles, front Bilstein 5100s, Eibach coils, Bilstein 5100 rear shocks, OMD leaf spring mod, Trail Gear low profile bumper, Black grill, JVC KW-HDR81BT head unit, Husky Liners, 5% tint all round, 50% tint on windshield with 9 inch strip, front Wet Okoles, stickers, and a rubber ducky on the antenna :D
    I'm running some synthetic 0w-40 Mobil 1 now. I have been using 5w-30 Mobil 1 but I believe it is a little thin for 30w.
  6. Feb 15, 2014 at 5:44 PM
    Hektor
    Texas
    I agree with you Mobil 1 5w 30 it's really thin
  7. Feb 16, 2014 at 6:24 PM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    Full syn, 5w30 autozone brand
  8. Feb 16, 2014 at 6:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    M1 5w20
    And there's already 5 or more threads just like this, some with polls.
  9. Feb 16, 2014 at 6:36 PM
    NYNURSE
    NYNURSE Well-Known Member
    Joe
    Rye, NY
    2011 TRD Sport
    Tonneau cover Window tint
    Dino. Oil and filter changed every 3500. 90% highway. I'll probably burn thru 2 frames before the motor gives up.
  10. Feb 16, 2014 at 6:38 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I run Redline fully synthetic
    It costs about twice as much as good dino; but, it's rated (and I trust it) to last, at least, 4 times as long
    So, the way I figure it... I'm actually saving money in the long run
  11. Feb 16, 2014 at 6:43 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I swapped to full synthetic 2 oil changes ago. Mobil 1 5w30. I will agree with the thin oil. I have a small tick, what seems to be a lifter tick, and it seems to be worse with this oil. Would a slighter thicker oil maybe the ticket? Like 5w20? Sorry to thread jack :D
  12. Feb 16, 2014 at 6:49 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    5w20 is thinner than 5w30
    5w30 is the proper weight for your engine.
    You have a 99... what are the valve adjustment specs and intervals for your engine?
  13. Feb 16, 2014 at 6:57 PM
    smmarine
    Melbourne FL
    Ok, I must have gotten confused and went the wrong way. Tbh, I don't know. And it probably hasn't been done and is past due. If I'm not mistaken I think it have heard the 3.4l valves are self adjusting? Maybe I'm wrong. I know there are shims that are supposed to be replaced every so often. At idle is an intermittent tick, but is steady with rpm when you drive. I can hear it, but a lot of people can't. I had my personal mech look at it and he said he wouldn't worry about it, but I know it's not normal.
  14. Feb 16, 2014 at 7:07 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If it has hydraulic lifters (self adjusting), then there are no shims to replace.
    I'm not familiar with the 3.4.
    Now, are you sure it's not an injector tick? That is a common complaint on the 2nd Gen.
  15. Feb 16, 2014 at 7:12 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    I have come to the consensus that these motors (3.4l) 'just tick'. They 'just do'. Mine does. And it pisses me off. Very noticeable from in the cab, only 118k.
    I just did my first oil change and used Mobil 1 I believe, but definitely synthetic. I used the recommended viscosity in the owners manual. I forget what it is. This sucker takes 5.5qt though!
    I used to use Royal Purple on my old truck, and was really impressed with the lubrication properties, but $11/qt is very hard to justify. I understand that you "can" go like 12-15k miles between oil changes with a quality oil like Royal Purple, but I would never do that.
    Oil needs to be changed frequently, but not for the reason you might think.
    When you drain your oil out at 5k (or even more) miles, it still lubricates fine, but it's turned black because of all the blow-by. After so many miles, your oil becomes more and more diluted with gasoline, which does not like oil function properly.
  16. Feb 16, 2014 at 7:14 PM
    smmarine
    Melbourne FL
    No it's not injectors. I know that sound, you can hear that as well. It's just a light tick. This is louder. My truck is very noisy. I have one of the loudest valve trains I have ever heard of the 3.4, which is already known to be loud. I have a buddy though that had his worked on by the same mechanic, and apparently he wishes his was a quiet as mine haha. Anyway, I've read there are shims that are supposed to be checked and replaced if out of spec, so I guess my valves aren't self adjusting
  17. Feb 16, 2014 at 7:17 PM
    smmarine
    Melbourne FL
    Oh these engines do tick! No doubt about that. I almost didn't buy it wen I heard it up to temp the first time. Sounded like it was about to fall apart. But I'm glad I did. Like I said, I swear I have the loudest valve train of any tacoma I hav seen. But this tick is different. It's louder.
  18. Feb 16, 2014 at 7:18 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    2013 TRD Magnetic Gray Double Cab
    Valvoline SynPower 5W30
  19. Feb 16, 2014 at 7:20 PM
    smmarine
    Melbourne FL
    Lol, first time I read this I thought you said you just did your first oil change at 118k. :eek:
  20. Feb 16, 2014 at 7:22 PM
    smmarine
    Melbourne FL
