What do you use Dino or synthetic oil???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Feb 15, 2014.
  1. Feb 16, 2014 at 7:26 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    First oil change since I got the truck. Actually this Tacoma is the opposite of my Nissan Hardbody I had.
    The Tacoma is quiet when cold, and ticks when up to temp.
    My Nissan would have the loudest lifter tap you ever heard when cold. I thought it was a rod knock for a long time. Best I can describe it is banging sledgehammers on thick metal. But when it warmed up, that thing was silent.
    What pisses me off most is the lifter tap is most of the reason I sold the truck. It still ran fine after 35k of tapping, I just couldn't stand waking the neighborhood up every morning anymore!
  2. Feb 16, 2014 at 7:30 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    I have been a diesel tech for over 23 years. If an engine comes with synthetic oil then use synthetic. . 1st gen Tacoma came with dino So I run dino. If you do regular oil and filter changes dino oil will be just fine. I have seen no benefit to using synthetic. I do about 30-50 oil samples on engines a month with dino and synthetic. Its all about regular oil changes......
  3. Feb 16, 2014 at 7:32 PM
    fast5speed
    Washington D.C.
    Agreed. I agree that regularly changing the oil is far more important that which type of oil.
  4. Feb 16, 2014 at 7:58 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I had the 2nd body style frontier(98) before the tacoma. Less then 60k miles when I wrecked it :facepalm:. It was always silent, but same engine, 2.4l right? I knew a girl who had a hardbody that did just what your describing. Sounded like it had no oil for 3 seconds haha. An my tacoma does just what your saying. Semi quiet(lots of fan, and a flowmaster :D), but ticks at temp
  5. Feb 16, 2014 at 8:01 PM
    smmarine
    Melbourne FL
    While I do agree with you about drain intervals, there are certain advantages to synthetic. Lower temps, better lube at extreme temps, extended drain periods, no oil breakdown. And most engines come from the factory on Dino to break in, because an engine will not break in correctly on synthetic
  6. Feb 16, 2014 at 8:04 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    2013 TRD Magnetic Gray Double Cab
    Plenty of High end engines come with Synthetic from the factory, no break in period needed.
  7. Feb 16, 2014 at 8:07 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You were doing pretty well up to this point.
    The Corvette and many other performance vehicles, including BMW and Mercedes, have been coming from the factory with synthetic for over 15 years.
    The 2.7 Tacoma also comes from the factory with synthetic and has since 2011.
    Same goes for almost all of the rest of the Toyota line.
    Only the 4.0 Tacoma, Yaris, and Avalon do not spec synthetic.
  8. Feb 16, 2014 at 8:16 PM
    smmarine
    Melbourne FL
    I stand corrected then. I was told that most engines wouldn't break it right or quick on synthetic because of how well it lubricates and to break in an engine on Dino oil
  9. Feb 16, 2014 at 8:18 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    Well I work on lots of engines that come with synthetic from the factory. As far as benefits the truth is in the pudding. I have engines with over 15,000 hours on them we do oil samples every oil change some run dino some run synthetic. The particle counts on the dino oil is no higher than the synthetic. Like I said we do anywhere from 30-50 oil samples a month on our customers engines. So I am talking from 20+ years experience ..
  10. Feb 16, 2014 at 8:28 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    I've been told a lot of things.
    I don't believe everything I've been told.
    I don't even believe everything I think...
  11. Feb 16, 2014 at 8:35 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    There was once a time that you had to break in an engine on non-detergent oil or the rings would not seat properly.
    Times have changed, and with them, engine construction materials, tolerances, and design.
    Sadly, a lot of old-school shadetree "mechanics" do not keep up on progress so they continue to repeat what they have heard for 30 years, be it a truth that is no longer true, or a myth that was never true.
    Every now and then I get caught on something that I was taught in the 70s and have to verify and re-think it.
  12. Feb 16, 2014 at 8:38 PM
    smmarine
    Melbourne FL
    I have learned something tonight!
  13. Feb 16, 2014 at 9:10 PM
    fast5speed
    Washington D.C.
    I had the 3.0 v6.
    Yep. Sounding like it had a lack of oil for a couple seconds would be the perfect description
  14. Feb 16, 2014 at 9:19 PM
    smmarine
    Melbourne FL
    She had the 2.4. And with 287k miles, she might not have had oil in the top at startup. It always made me cringe every time she started it up haha
  15. Feb 17, 2014 at 12:26 AM
    #35
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    This is the reason I stopped using M1 because if a tick or valve noise. I went back to Dino and no more noise.
  16. Feb 17, 2014 at 2:25 AM
    #36
    Terminal4
    Terminal4 Well-Known Member
    South of the Sierras
    2022 DCLB 4WD
    Accutuned Fox suspension, Wildpeaks AT4, Batzmaru
    Hah my buddy says the same exact thing; he was also a diesel mech for 15 years, works at irvine chevy now...my rig just hit 230k, runs great wth dino 5w30 every 3500 miles..
  17. Feb 17, 2014 at 2:33 AM
    #37
    WThomas1250
    WThomas1250 Well-Known Member
    I use "High Mileage" dino oil. Seems to work well, after a few months of me changing it myself (using better oil than my mechanic) my truck has stopped leaking
  18. Feb 17, 2014 at 4:16 AM
    #38
    smmarine
    Melbourne FL
    Mine had the tick on Dino. Just seems to make it a little louder on m1. I prefer to run sythetic mostly for the extended drain intervals. I'm gonna be doing a oil analysis at 5k to see how long I can push it. There's a guy on here who was at 11k and they told him to had 2k more according to his analysis. He also has well over 300k on his truck. I think it's like 317k, and he's been doing drain intervals at about 10k regularly. That's something you can't do with Dino oil
  19. Feb 17, 2014 at 6:14 AM
    #39
    yoterdude
    yoterdude Well-Known Member
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Aero Turbine 2525, Aero tip, AFE Dry Pro S filter, deckplate mod, TRS Morimoto Mini H1 projectors, TRS xBLed angel eyes, Vent visors, Blacked out tail lights, LED turn signals, 10w LED auxiliary reverse lights, 20in LED light bar, OTRATTW switches, LED interior lights, Blue needles, front Bilstein 5100s, Eibach coils, Bilstein 5100 rear shocks, OMD leaf spring mod, Trail Gear low profile bumper, Black grill, JVC KW-HDR81BT head unit, Husky Liners, 5% tint all round, 50% tint on windshield with 9 inch strip, front Wet Okoles, stickers, and a rubber ducky on the antenna :D
    Mobil 1 is notorious for ticking in the top end. I'm trying this M1 0w-40 but its still ticking some. I'm thinking about trying some German Castrol 0w-30 to see if it will stop.
  20. Feb 17, 2014 at 12:20 PM
    #40
    MaterTaco
    MaterTaco Member
    Javan
    Clyde, NC
    15 DCSB TRD OR
    Coming soon
    I run Castrol 5w30 full synthetic and have no noise or leaks. But it does use about a quart every 5k miles, which is how often I change oil.
