What do you want in an all electric Tacoma?
Discussion in 'Electric Vehicles (EVs)' started by Bigbadbucki, Jul 5, 2022.
  1. Jul 5, 2022 at 9:56 AM
    gemiv19
    gemiv19 Well-Known Member
    Ted
    Central Point OR
    2024 DCLB TRD OR Blue Crush
    Totally Stock for now
    This is spot on. There are already rolling brown outs in major metropolitan areas. My other concerns with a fully electric off-road vehicle are. First, how will the vehicle peform in the wet of winter snow, water crossings and mud. Secondly now when going backcountry you will have to carry fuel and a generator.
  2. Jul 5, 2022 at 10:03 AM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    Im pretty sure you can charge an EV just with an appropriate number of solar panels without even being plug-in to a grid.
    It doesn’t need to fully impact the grid. With every house having solar, we should be fine at least in my area (west/south west). For other regions, it’s going to be a problem for sure.
    However, I drive maybe 20-30 miles each day. I struggle to understand why I would even need range of 850 miles. In fact, I’m looking to buy a used Nissan Leaf with 100mile range tops. I don’t need anything else.
  3. Jul 5, 2022 at 10:08 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    These desires will all come to pass, sooner than you think, with the exception of the 2 naked ladies.
    Electric air-taxis are on the horizon, ( JOBY )... battery technology of this scale is still in its infancy but is evolving rapidly.
    Living in the desert the solar thoughts are interesting for sure.
    Yes, the by product of these batteries isn't pretty, and in some respects produce just as much pollution as oil, however I suspect these will be much
    easier to resolve than what we've seen over the last 100+ years of oil pollution. And don't forget that producing the electricity to charge these massive
    batteries has its own set of issues.
    Will it save the planet?... no, too late for that.
    Will it save our pocketbooks?... no, too late for that as well.
  4. Jul 5, 2022 at 10:08 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I'm moreso referring to on the grid when out and about. Home charging should not be an issue, but trip range and using the vehicle for anything other than running around town can be an issue - especially as batteries age and range suffers. Not to mention how long it takes to charge the current EV's @ charging stations. Plus for a 4x4 application, it's going to stress the batteries much more due to load and likely wear them down significantly faster. Sure you can do things like on-board solar and regenerative braking to help recharge, but in general it's a big nope from me dawg.
  5. Jul 5, 2022 at 10:29 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I left my battery powered leaf blower out in the rain. I was surprised it still worked, but then the battery would not take a charge.
    I'm sure the batteries in a BEV are a little more advanced, and might be better sealed.
    What happens if you drive your F-150 Lightning through flood water, maybe just a foot or two of water on the road. Something that can be quite common when driving through low elevations. Will the batteries stop working, or no longer accept a charge?
  6. Jul 5, 2022 at 10:31 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Big heavy powerful trucks need big heavy expensive batteries that require loonngg recharge times. A step backwards, Me thinks!
    Fire Arrow likes this.
  7. Jul 5, 2022 at 10:32 AM
    anangrymarmoset
    anangrymarmoset Member
    2010 access cab 6 cyl 4x4
    Built in generator for when you can't get a full charge and ability to operate off that generator to the electric motors (just in case). Also, solar ready.
    erwigg likes this.
  8. Jul 5, 2022 at 10:33 AM
    willie2
    Nova Scotia Canada
    4 Banger 5 spd
    Aren't the batteries sealed and liquid cooled?
  9. Jul 5, 2022 at 10:36 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    that is not a common situation.
  10. Jul 5, 2022 at 10:37 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    I don’t see diesel going away any time soon, but I could see petro engines declining in demand.
    freight is carried by either Diesel electric trains or diesel semis. There’s no viable alternative for those transportation methods
  11. Jul 5, 2022 at 10:40 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Yeah! Delete electric, give us a v8.
  12. Jul 5, 2022 at 10:40 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    350+ mile range, ten-ish minute full charge, copious amount of chargers all over podunk nowhere, and superb reliability is all.
  13. Jul 5, 2022 at 10:49 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    What do I want from an E/V Taco - nothing. However, if it should come to market before I'm ready to replace my '21 TRD OR, my 'Must haves' are:
    - Fully recyclable and environmentally friendly batteries made in the USA from non-Chinese components.
    - Batteries that'll last at least 10 years before replacement is necessary.
    - Reasonable recharging time from a home-based 240VAC charger.
    - Cheaper electric rates in CT (currently paying 24.6¢ per kWH).
    - Less 'Mommy-state' features.
    - Same or better payload & towing capabilities.
    EDIT:
    - Would much rather see a Hybrid Diesel/electric with self-charging capability.
    erwigg likes this.
  14. Jul 5, 2022 at 10:54 AM
    batacoma
    batacoma Truck Wars
    I think they are air cooled, sealed probably. It might not be possible to saturate the sealed batteries, as they can prove difficult to extinguish once ignited. I guess the cooling system becomes ineffective, and that's what causes the batteries to ignite in a crash.
    Sometimes the entire vehicle/battery has to be submerged, and there is an extinguishing system that pierces the battery to get water to it.
    Edit I meant liquid cooled.
    Also my previous post about accessories preserving rechargeable battery life. Probably has no impact on batterylife/range. I think all accessories are powered from the 12v system, like ice. Istill like the idea, if 12v isn't powering accessories.
    I doubt if it's a common situation, probably about as common as hydro locking an ice vehicle in flood water. Less BEVs on the road, so it isn't likely. I'm still interested in what the outcome is.
  15. Jul 5, 2022 at 10:55 AM
    #35
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    just this:
  16. Jul 5, 2022 at 10:57 AM
    #36
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    500+ mile range.
    6000 lbs towing capacity.
    Electronically adjustable suspension height.
  17. Jul 5, 2022 at 12:06 PM
    #37
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Did someone compare leaving a leaf blower out in the rain to driving a truck through 2 ft of water?
    DarthPow and TX BAJA1 like this.
  18. Jul 5, 2022 at 12:07 PM
    #38
    rainsux
    rainsux Well-Known Member
    2021 Tacoma Off Road
    None.
    BEV pick-up’s suck for towing duties. Hook up an RV and the Lightning’s range dropped from 300+ to < 100 miles of driving the Colorado front range. Imagine what happens in cold weather with four snowmobiles on the trailer …
    https://youtu.be/-e55Vued028
    vivid02, Deeahgee and auskip07 like this.
  19. Jul 5, 2022 at 12:12 PM
    #39
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    Diesel engine.
  20. Jul 5, 2022 at 12:12 PM
    #40
    saint277
    saint277 Vigilo Confido
    I want a nuclear powered taco.....
    Superdave1.0, Sprig and Slashaar like this.
