What does "A/T p" and "A/T oil temp" stand for on cluster?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Feb 16, 2013.
  1. Feb 16, 2013 at 4:31 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Just bought a cluster to do a cluster swap to get a tach in my truck. On the left side where it indicates engine temp, there is "A/T P" and "A/T Oil Temp" written. Does that stand for Automatic transmission?
    This tac, supposedly came out of a 4cyl, 5spd, so I'm a little confused. Also a little angry b/c I have a 4cyl, 5spd, and supposedly you have to get the tac from a truck with same engine and trans, or the RPMs will be incorrect.
    I searched through countless photos, and found automatic trucks without that written there, and one pic of a manual with it, so now I'm a mixture of confused/angry, and if I didn't just spend $100 on this stupid cluster, I'd shoot it. :cool:
    KGrHqRHJEMFD1mW-pWBQsdGWQ60_3_zps2e6506b_6709b55602971b65d3b342bb715ce362524a6145.jpg
    KGrHqJHJEUFDv1KgnNBQsg679Q60_3_zps67d1e0_72ad6907a42dc1ed9c9ec95c3a6d73ef3a2520c6.jpg
  2. Feb 16, 2013 at 4:35 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    auto transmission pressure and auto transmission oil temp. atleast thats what i would believe it is
  3. Feb 16, 2013 at 4:44 PM
    SpeedoJosh
    Florida
    That's what I figured. Dangit. Looks like it came out of an automatic and not a manual. Which I'm told is not compatible with my manual truck. :mad:
  4. Feb 16, 2013 at 4:52 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Plug it in and see what you get. Someone here could probably confirm the values for you. It might work, might not.
  5. Feb 16, 2013 at 5:00 PM
    SpeedoJosh
    Florida
    Yea, I was thinking about that, and I'm sure the tachometer would move, just not sure if it'll read the correct RPMs, being different transmissions.
  6. Feb 16, 2013 at 11:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you really need an analog RPM gauge? A scangauge will give a digital readout of of RPMs, and so much more.
  7. Feb 16, 2013 at 11:35 PM
    SpeedoJosh
    Florida
    I prefer the stock look. I had an edge in my last truck and it even came with a pod that matched the dash, but still didn't have the clean look of stock. Plus my current gas gauge is reading wrong, so that is also swaying my decision to a new cluster.
  8. Feb 17, 2013 at 12:13 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The auto/manual cluster may be the same. They don't always make different faces for different configurations. My '95 Suburban cluster had the sockets and lettering for the 6.5l Diesel.
  9. Feb 17, 2013 at 8:48 AM
    SpeedoJosh
    Florida
    Yea, I searched ebay, and autotrader yesterday for two hours looking at pics of tacomas. Found a dozen or so pics of automatic trucks with those indicators, but no manuals. Found a lot more of auto trucks that didn't have these indicators. Guess this is a rare cluster for an auto.
    Since this cluster did come out of an automatic, what about it's rpm readings would make it read wrong putting it in a manual. Is it some pre-programmed computer stuff that'll give me a headache just thinking about, or something else all together?
    **Added pic for better reference, also one with part number incase someone has the book-o-part numbers sitting beside them.**
  10. Feb 17, 2013 at 8:55 AM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Doesn't the tach read the signal from the distributor or ignition coil?
  11. Feb 17, 2013 at 9:00 AM
    A3umph
    A3umph Well-Known Member
    outside of KCMO
    '12 Tacoma Access Cab TRD OR
    Tach will work off of engine RPM not off of drive through transmission. There could be a difference between 4 and 6 cyl. The older aftermarket tachs usually had a wire you had to change to be able to use in 4, 6, or 8 cylinder vehicles. Try it and see is my opinion.
  12. Feb 19, 2013 at 12:08 PM
    Aquasonic
    Aquasonic Active Member
    Near Columbus Georgia
    1996 LX 4x4 2.7L4
    PM sent.
  13. Mar 3, 2013 at 10:42 AM
    SpeedoJosh
    Florida
    Plugged it in and RPMs seem to be reading low. Guessing the cluster came out of a 6cyl.
    Drove around, and with my normal shifting, I never got to 2k rpms. If I rev'd it out, I made it over 2k (on the tach), but sounded like it was running higher.
    For example, running in third gear, speedo said 40mph, and tach read about 1500.
    To top it all off, I broke the surround taking it out. It was stuck somehow around the left vent. FML, I'm done with working on this truck. Putting the old cluster in, going to order a new surround, then not touching another thing on this truck. :mad:
