What does M/T mean?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BBogey, Jun 19, 2023.
  1. Jun 20, 2023 at 2:01 AM
    #41
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    MIGHTY TACO
    Hertel Ave, Buffalo, NY
    Jml248 and SH10151 like this.
  2. Jun 20, 2023 at 3:00 AM
    #42
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    No worries....welcome to TW! M/T = Mud Terrain tire but if you see MT or 6MT it means manual transmission. And just cause if you see M/T you will also see A/T it is All Terrain tire.
    Benny blanco and BBogey[OP] like this.
  3. Jun 20, 2023 at 1:19 PM
    #43
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Or auto trans and manual trans
  4. Jun 20, 2023 at 1:32 PM
    #44
    photodoc
    Northern Kentucky
    '23 TRD PRO 6MT
    typically not with a "/" for transmission type
    Charlie Bravo likes this.
  5. Jun 20, 2023 at 1:58 PM
    #45
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Americans are so starved for manual transmissions and there are so few of them left that a car manufacturer could offer one with weird gear ratios, rubbery shifting, self destructing T/O bearing, and imprecisely engaging clutch and people would still line up and pay a premium for it.
    Also M/T stands for meatballs and tater tots.
    apowers and amyracecar like this.
  6. Jun 20, 2023 at 2:11 PM
    #46
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Matchbox Truck. :D
    SH10151 likes this.
  7. Jun 20, 2023 at 2:47 PM
    #47
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Man Titties?
    SH10151 likes this.
  8. Jun 20, 2023 at 3:24 PM
    #48
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    SH10151 likes this.
  9. Jun 20, 2023 at 3:33 PM
    #49
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    "M/T - It is what makes your forearms bigger :anonymous:
  10. Jun 22, 2023 at 7:08 PM
    #50
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    A place I worked many years ago had an elderly Ford with a 3 speed on the wheel.
    Below is what is in the engine compartment at the bottom of the column, the top arm is for low/reverse, the bottom arm second/high, they go to the transmission.
    There are unseen springs that hold the sandwich together, the photo shows the assembly in neutral.
    The bit in the middle with the orange arrow is what is connected to the shifter.
    There is a pin on each side to work the arms.
    Well, all that stuff wears down and gets floppy and sloppy. The old Ford had a nasty habit of jamming when shifting from low to second. It wouldn't be out of first but wouldn't go into second and wouldn't go back in to first.
    Without fail this happened in the middle of an intersection... :censored::censored::censored:
    If there were two people it wasn't so bad, the driver could hold the clutch down and move the shifter, the other guy could pry the levers back in the right place with a big screwdriver.
    If you were alone...:mad:
    You are in the intersection trying to rock the truck and pry on the levers at the same time.
    With practice (and a bit of prayer perhaps) it worked ok, one minute of inattention however found you swearing in the middle of an intersection as other drivers swore at you.
  11. Jun 22, 2023 at 7:11 PM
    #51
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :101010::101010::101010:
  12. Jun 22, 2023 at 7:32 PM
    #52
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    Now that you mention it, I returned to my apartment in Cody, Wyoming one day to ask the movers about moving the Rambler and they showed how they easily moved it into neutral without having to get into the car. They just pushed it to a different spot to get their truck in. Later that year, I'd have trouble that turned out to be the nut loosening at the transmission linkage arm, and another that an adjuster piece had been lost from the self-adjusting clutch (probably while someone was trying to replace the transmission with an overdrive version. Crawling under the car with a wrench or two isn't much of a problem in your early 20s... Now, I try to avoid stoop labor. We can get down on the ground as fast as we used to, but getting up takes a bit longer...
  13. Jun 23, 2023 at 5:35 AM
    #53
    jLEE028
    jLEE028 Well-Known Member
    MKE
  14. Jun 23, 2023 at 5:38 AM
    #54
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    Double brilliant! Pause, Stop, Go! Took me a moment to recognize this. :D:thumbsup:
  15. Jun 23, 2023 at 8:52 AM
    #55
    remote
    remote Well-Known Member
    Minnesota
    2021 DCSB Sport Cement
    Mickey Thompson
    Taco22trdor likes this.
  16. Jun 23, 2023 at 10:19 AM
    #56
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    All this time I thought m/t stood for military transport
  17. Jun 23, 2023 at 10:36 AM
    #57
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    MASSIVE TIDDIES hell yeah
    It's Friday.
  18. Jun 23, 2023 at 11:55 AM
    #58
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  19. Jun 23, 2023 at 11:56 AM
    #59
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Mexican Tacos
    HondaGM likes this.
