What does toyota use as a oem clutch ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma2wd1999, Jan 19, 2015.
  1. Jan 19, 2015 at 11:14 AM
    tacoma2wd1999
    tacoma2wd1999 [OP] Member
    josh
    socal
    99 tacoma 2wd 5spd
    Tow hitch
    I'm thinking about replacing my clutch soon on my 99 2wd 2.4L. .can anybody tell me what brand clutch toyota uses when you buy the truck bran new off the lot ?
  2. Jan 19, 2015 at 11:25 AM
    tacoma2wd1999
    josh
    socal
    99 tacoma 2wd 5spd
    Tow hitch
    Ok so who makes their clutches? I use mine for towing and no issues but at 176.000 I'm guessing it's about time .
  3. Jan 19, 2015 at 11:28 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    If you want a clutch that will never wear out get a Center Force. I've used them and been very happy.
  4. Jan 19, 2015 at 11:42 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I want to say OEM is Aisin but I could be wrong.
  5. Jan 19, 2015 at 6:42 PM
    tacoma2wd1999
    josh
    socal
    99 tacoma 2wd 5spd
    Tow hitch
    I've used a LUK clutch on my 91 4 cyl and no issues.
    hope someone might Have an answer
  6. Jan 19, 2015 at 7:09 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    They've switched back and forth between Luk and Aisin clutches over the years. My 2011 had a Luk and I hated it, was too weak and I burned it a few times trying to heel and toe start on steep hills. I have an automatic now so no longer have to worry about that issue thankfully.
  7. Jan 19, 2015 at 7:14 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    They use the crusty end of a loaf of (bran infused) bread as a pressure plate....
    ... True story!!
