what does your oil look like?
Discussion in 'Performance and Tuning' started by malander, Dec 30, 2010.
  1. Dec 30, 2010 at 7:52 AM
    malander
    malander [OP] That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    So my dad insists on running 10w-40 in my truck and changing every 5000 miles, but after looking at the used oil I'm having some thoughts about switching over to a 5w-30 synthetic despite having 107,000 miles and being fairly "abused" oil wise.
    It would help to see some pics of your guys' used oil so that I can make sure that this black cruddy crap is normal (which I suspect it's not). This might also make a useful thread to anyone who is considering a different weight or brand of oil so post up some pics of your used oil!
  2. Dec 30, 2010 at 8:14 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Well.....umm... The owners manual recommends 5W-30.
    In both my 96 and this 07 - the oil was very dark. Not black, but very dark brown (dark chocolate). So - I'd say its pretty normal.
    Do some research about changing to synthetics at such high mileage. You can do it, but I know from my own experience.... I changed my 96 tacoma to synthetics @80k miles, oil started seeping around at the oil pan and I was consuming about 1/2 quart of oil every oil change.
    Also, you could do some sort of engine flush to try and get rid of the sludge - HOWEVER - you might create new problems by doing that. Again - do some research.
  3. Dec 30, 2010 at 8:17 AM
    malander
    max
    Missouri
    01 limited trd 4x4
    yeah I know 5w-30 is recommended but it all ends up not being my choice
  4. Dec 30, 2010 at 8:23 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    amsoil 0-30
  5. Dec 30, 2010 at 8:23 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Your dad forces you to use the wrong oil?
  6. Dec 30, 2010 at 8:25 AM
    Janster
    Jandy
    Lancaster, PA
    Not to sound like a smart ass - but if that's the case, then why are you asking?
    Are you looking for reasons to convince your dad?
  7. Dec 30, 2010 at 8:29 AM
    crf69
    Ohio
    ummm yeah
    wrong oil....what does that mean? really? amsoil is the best in the world end of convo
  8. Dec 30, 2010 at 8:46 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    5w-30 is recommended for the slight fuel efficency improvement with the lower viscosity. In Missouri, I doubt you ever see temps cold enough to have to run a 5w.
    A 5K interval isn't terrible. I choose 3K for my intown driver and 5K for the highway vehicle. I also run dino juice since the intervals are short. I am a big fan of synthetic gear oils but not so much on engine oils.
    The black stuff you see if carbon that is blowing past the rings. It is normal and it does get worse with age on the engine. The other stuff you can't see in the blow by is forming acids that collect in your oil. That is the best reason to change it often!
  9. Dec 30, 2010 at 10:16 AM
    malander
    max
    Missouri
    01 limited trd 4x4
    because what he doesn't know won't hurt him and like anyone I want to treat my truck well
  10. Dec 30, 2010 at 10:20 AM
    malander
    max
    Missouri
    01 limited trd 4x4
    well....yeah. I asked him about it and all he said was that for weather in missouri it shouldnt matter. Mind you we have had some single digit mornings and what not. He would rather stick to 10w-40 even though for the past 95000 we've used 5w-30. My dad is a weird guy when it comes to this type of stuff. he buys and restores really expensive stuff and ends up treating it like shit. He bought a '72 MGB and has since had to restore it twice, but due to neglecting it once again its sitting in our garage with serious engine, rust, and interior issues.
  11. Dec 30, 2010 at 10:48 AM
    Taco John
    Illinois
    4X4
    I wouldn't worry about the viscosity that much - 5W vs. 10W in your neck of the woods. Just stick with an SM rated multigrade and you will be fine. Has the truck been using oil lately? He may have upped the viscosity a little to reduce the oil usage in an older engine.
  12. Dec 30, 2010 at 10:49 AM
    malander
    max
    Missouri
    01 limited trd 4x4
    she runs alright, no oil consumption. I'm just lookin to do whats best for it thats all
  13. Dec 30, 2010 at 10:52 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Napa gold filters are excellent for extended oil change intervals.
  14. Feb 7, 2011 at 1:51 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    5k is a bit long for me, I change it when the oil on the dipstick looks medium brown because what drains from the pan always looks much darker of course. Usually ends up around 4200-4500 mile OCI (5w30 dino oil). Last time I took used oil for recycling, the girl at VatoZone commented that there is still some clarity to it so I could go to 5k easily, I just choose not to. Oil is cheap, engines are not.
    I used to be a real stickler about "name brand" oils but in reality the best kind of oil is the oil that is changed often.
    Wait... is that a petrolueum company salesperson? *barf* :puke: crf69 I just had to...
  15. Feb 7, 2011 at 1:58 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I did 5k on conventional penzoil the first 2 changes with my truck before switching over to synth at around 156k, no leaks and it doesn't burn a drop between changes and im at 165k now doing 5k OCI's with the stock toyota filter.
  16. Feb 7, 2011 at 8:58 PM
    DGXR
    Friend
    Sacramento, CA
    That is good news for anyone thinking about switching to synth after many many miles.
    It sounds like you went 156k on 2 oil changes. But it must have had ~145k when you bought it... ? ?
  17. Feb 7, 2011 at 11:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    146k;)
    yeah sorry, a bit misleading
