What don't you like about Doug Thorley
Discussion in 'Performance and Tuning' started by Bellis, Feb 10, 2014.
  1. Feb 10, 2014 at 9:51 AM
    Bellis
    Bellis [OP] friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    Hey guys I'm about to buy some Doug Thorley long tube headers and although I want to hear positives I'm curious what type's of failures others have encountered, kind of getting prepared for the worst and expecting the best with these
  2. Feb 11, 2014 at 5:25 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    I've installed 2 set in the past on 2 different Tacoma (2005 +2011) and never had any problem with them. In fact, never read something about failure related to it.
  3. Feb 11, 2014 at 5:30 AM
    Bellis
    Ben
    mass southshore
    driver mod
    neither had I which is why I was curious about failures, fitment problems or possible negatives to the long tubes I wasn't expecting, it's nice to hear positives though
  4. Feb 15, 2014 at 6:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have. The driver side transmission bracket doesn't line up properly onto the Y-pipe flange. If you don't slot the bracket's hole, then it will crack the flange at the merge collector.
  5. Feb 15, 2014 at 6:48 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    really? only issue i ever had was the passenger side trans mission bracket bolt falling out at the header. did it twice. only thing to happen was the header/ypipe banging around makin a god awful noise
  6. Feb 15, 2014 at 7:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. Happened to mine, and happened to Lucario Runner's. His set are in my garage right now, still cracked. Or maybe we fixed it. Cannot remember. He had the bolt falling out problem as well. Upgraded to better hardware and problem solved.
    The bracket flange problem is also there with the URD Spec-U driver side header.
    When we installed those on his truck (although they were a pre-production set) the holes didn't line up, and it was threaded to small. Had to drill out the hole larger, on the header flange, and elongate the hole on the bracket.
  7. Feb 15, 2014 at 7:42 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Never met him
  8. Feb 15, 2014 at 7:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    o_O Say hwat?
  9. Feb 20, 2014 at 4:52 AM
    Bellis
    Ben
    mass southshore
    driver mod
    how did I miss these responses
    what type of hardware upgrade we talkin bout? and mine is a 2012 so its a little different maybe my bolt pattern will line up when they get here, if I'm lucky
  10. Feb 20, 2014 at 5:41 AM
    Bellis
    Ben
    mass southshore
    driver mod
    also I saw a write up where the guy did not use the transmission bracket what are the risks involved with this
  11. Feb 20, 2014 at 5:43 AM
    reece54
    reece54 Well-Known Member
    Reece
    91765
    16' 4x4 trd off-road
    Trollololol
  12. Feb 20, 2014 at 7:02 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I cannot remember which grade bolts that came with the headers. For the header to Y-pipe flange. We just installed Grade 10.8 (9?) bolts with the self locking nuts. The kind which have the serrated bottom, at the mating face. Can't remember what those are called either. Lol. One of those mornings.
    Over time, if the trans support bracket isn't installed, the headers will crack, at the rear most primaries. Happened to mine. Then you have to go and get the re-welded.
    Reason being, is due to the whole exhaust being able to flex all the way to the headers. Those brackets help support the weight of the Y-pipe (which is quite heavy) , as well as isolate it from the catback. There are spring bolts, and a donut gasket at the rear of the Y-pipe, which is to allow the catback to flex. Also a much cheaper alternative to the stainless flex couplings seen on more expensive vehicles.
  13. Feb 20, 2014 at 7:39 AM
    Bellis
    Ben
    mass southshore
    driver mod
    good info to know, thanks, do you have any pics of the slotted hole?
  14. Feb 20, 2014 at 10:26 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    x2................
    I cant remember any fitment issues, but I may have just been in a hurry and forced things... I rlly cant recall
    were Roberts the 1st or 2nd version headers?
  15. Feb 20, 2014 at 10:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    2nd Gen DTLT's , 1st gen Spec-U's.
