What don't you like?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by slevy951, Apr 26, 2025 at 6:20 AM.
  1. Apr 27, 2025 at 5:34 AM
    #41
    BillyE
    BillyE Well-Known Member
    This is my biggest gripe, but I would say it’s pretty much solved on my truck. It’s a gripe that I don’t believe the automatic transmission folks can appreciate.
    Have you ever tried higher octane? It makes a big difference in mine. I’ve done a few other things, but octane gets you halfway there…in my experience
  2. Apr 27, 2025 at 7:06 AM
    #42
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Yep, 93 octane for over 2 years and now 90 octane no ethanol. Hasn’t changed for me. Same for different tunes, it’s always there. It maybe got a bit better with octane, but it’s been so long that it’s hard to say.
    And yes, I agree with you that the autos don’t get it. I had a loaner auto for 2.5 weeks while mine got a warranty repair, and the auto completely sucks in its own way, but it doesn’t have any of the throttle hesitation that the manuals have. So auto owners definitely don’t understand what we’re talking about unless they’ve driven one.
  3. Apr 27, 2025 at 7:12 AM
    #43
    BillyE
    Ok. I’ll tell you what I’ve done. I use exclusively 93 octane. Anything less is immediately noticeable. I have the OTT tune, Anderson spacer, and unplugged ACIS. I’ve arrived at that point with a lot of experimenting. It’s not faster than it was stock, but it’s a lot more drivable.
    BLtheP[QUOTED] likes this.
  4. Apr 27, 2025 at 7:25 AM
    #44
    BLtheP
    Plano, TX
    I used to use 93 but eventually I started getting chirping from the high pressure fuel pump. Ethanol free fuel fixes that, so that is what I run now. I can only get that in 90 octane.
    I have OTT. It’s okay, but I still get it to bog down constantly.
    Haven’t tried the Anderson spacer, but I have been interested in it before. Just never pulled the trigger.
    I have unplugged the ACIS before. For whatever reason, that felt like it was worse after…one thing I’m not sure about is if it’s spring loaded? I wonder if you unplug it, is the flap free to flip into either position, does it stay where it was, or does it spring back to its natural position? Not sure, and so I couldn’t determine much other than my low end was worse with it unplugged and it went back to normal once I plugged it back in.
  5. Apr 27, 2025 at 8:37 AM
    #45
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I tried 3 tanks of 93 octane. Perhaps a placebo of slightly better power under the curve but nothing that makes me believe it's worth the $20 extra per fill up.
  6. Apr 27, 2025 at 10:19 AM
    #46
    pbdude123
    pbdude123 Member
    My only complaint is backing up in small parking lots. The double cab is a very long vehicle, even with a 5 1/2 ft bed. It's difficult to see when backing up in tight places. I took out the middle headrest from the back seat to get better visibility. The backup cam helps, but it's diffucult to judge distance using it.
  7. Apr 27, 2025 at 11:11 AM
    #47
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    You probably mean you HATE the way that the transmission performs because of the factory settings. Once that annoying issue is looked after it becomes a smooth shifting, non gear hunting, well-oiled machine! (My personal experience spanning the past 6 yrs)
  8. Apr 27, 2025 at 11:50 AM
    #48
    Johnsmyname
    Johnsmyname Active Member
    Disagree underpowered. As others have said, it’s a v6 and needs (and was made for) high rpm’s. I do prefer low end power of a v8, but the 3.5 does just fine for a pickup truck. I would only feel underpowered if doing a lot of heavy towing, but I also wouldn’t have bought this truck if I was.
    Agree with cheap quality of trim plastic is most disappointing quality. Both interior and exterior plastics scratch way too easy for a vehicle. They also fade and look like crap way too fast. The one positive thing I noticed though is that the trim tabs and clips do not break and things go back with the same tightness as before. That’s a first in my experience.
  9. Apr 27, 2025 at 12:16 PM
    #49
    yotadust
    yotadust Well-Known Member
    SR 4X4 OFFROAD
    3rd gen cabin is squashed like a pancake. I can touch my thumb to the floorboard with my pinky touching the top of the seat. It's basically a gokart. when I drive with my feet all the way back to the seat on cruise control my knees are halfway up the steering wheel for the love.
    with the 4th gen they needed to increase the the floor to ceiling height and seat to ceiling height by around a foot. They gave it two more inches. for the love.
    the cabin is about 1 foot too short front to back. If y'all all want it to fit in garages for some crazy reason they should have extended the cab by 1 foot and took that foot out of the bed making it 4ft bed. This would add an extra foot of leg room for the back seat. Perfect.
    drop the prior gen 4runner 4.o and trans in it and it and add a front locker itd be perfect.
    and then take my money
    TacoDell60 likes this.
  10. Apr 27, 2025 at 12:21 PM
    #50
    yotadust
    SR 4X4 OFFROAD
    ill be happy with the north American Tacoma once it is this
    TacoDell60 and Curveball30 like this.
  11. Apr 27, 2025 at 12:30 PM
    #51
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    I hate that I can't get out on back country or FSR more often exploring with this truck. Stuck like most, daily driving 95% of the time working to pay bills and doing mundane domestic chores. But when we can escape, no complaints.
    Irons likes this.
  12. Apr 27, 2025 at 12:48 PM
    #52
    yotadust
    SR 4X4 OFFROAD
    I bet y'all have some amazing trails to ride up there in BC. I've been wanting to hunt there for a loooooong time. Most exciting trails get here in FL is all flat with sandy holes and small stream crossings...
  13. Apr 27, 2025 at 1:08 PM
    #53
    Canadian Caber
    Les
    B.C. Canada, eh
    Yes, you are correct. We also have some diverse areas here as well. Coastal rain forests, inland deserts, spectacular sub alpine meadows and glaciers. From the southern Can/Am border to the Arctic ocean in the north. At the end of the day, anything outdoors is better than the concrete jungles. Every area always has some interesting features if you stop watch and observe. Can I just win the lotto and do that full time?
    Curveball30 and Tacosha like this.
  14. Apr 27, 2025 at 1:48 PM
    #54
    BillyE
    No don’t spend that if it doesn’t help you. On mine, benefits of 93 octane are obvious within 1/4 tank. It’s odd that it helps some and not others. It’s not placebo in my case. It’s night and day improvement.
  15. Apr 27, 2025 at 3:58 PM
    #55
    BillyE
    Unplugging it makes more sense with the spacer. Alternatively, you could reprogram the engine speed that it opens to a lower rpm. I did it entirely to get rid of the big jerk that occurred at 3600 rpm with the OTT + spacer. I didn’t notice any negative impact.
  16. Apr 27, 2025 at 4:09 PM
    #56
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    I wouldn't swap a 3.5L Tundra motor in it. Too much of a risk of it blowing up :rofl:
  17. Apr 27, 2025 at 4:16 PM
    #57
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    modern EPA approved automotive paint/clear coat is weak sauce...that's about it...
  18. Apr 27, 2025 at 5:21 PM
    #58
    yotadust
    SR 4X4 OFFROAD
    have you seen the 4th gen manual console? Not sure what they were thinking when they designed that. Looks like they just threw it together with a bunch of parts they had laying around from the automatics. No storage at all in front of the shifter and shift skirt is massive and a weird shape like they were covering a hole made for something else. You think it looks right? Where are you going to put your phone?
    dnlskier, SandyTaco4x4 and Kolohe07 like this.
  19. Apr 27, 2025 at 5:34 PM
    #59
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    I thought the same thing when mine was new. After about a year, it more or less settled down. Don't notice it at all now.
  20. Apr 27, 2025 at 6:50 PM
    #60
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    its shaped like that for reverse gear. its actually same size or smaller than the 3rd gens
