What driving aids to turn off doing some trails?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Erik37, Oct 2, 2012.
  1. Oct 2, 2012 at 6:19 PM
    Erik37
    Erik37 [OP] Well-Known Member
    Langley, BC, Canada
    2012 DCSB TRD Sport 6spd leather
    I can't find where my wife put my owner's manual but I figured I could get a quick response on here. I was wondering which (if any) driving aids should be turned off when going off road? Won't be anything crazy, this will be the first time I've ever gone off road. It's a stock 2012 TRD Sport 4x4.
  2. Oct 2, 2012 at 6:20 PM
    jandrews
    '09 FourDubDee TRD OR
    It. Depends.
    I recommend researching thoroughly what they all do and deciding for yourself when you want them on or off.
    Many of them are both beneficial and problematic depending on the type of terrain.
    I'm starting to get a better feel for what works well and when, but shit's somewhat complicated.
  3. Oct 2, 2012 at 6:21 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    As soon as you engage it into 4 low, it turns off a bunch of things, all the lights will come on in the dash. I am assuming those are all the things ya need off, don't know of any other way to turn them off either.
  4. Oct 2, 2012 at 7:32 PM
    badger
    badger Well-Known Member
    07 SR5
    JAndrews posted this excellent summary on another forum (post #3):
    It's worth a read.
    I'm sure glad I'm not learning how to wheel with all this stuff. The rigs I learned in didn't even have shoulder harnesses :D
  5. Oct 2, 2012 at 7:38 PM
    jandrews
    Not necessarily. Plenty of times lockers are essential in sand, and they can be helpful in other items.
    The key tends to be wheelspeed vs. not. Because of the ABS modulation of wheelspin, these electronic traction aids *rarely* help when what you really need is two tires spinning rather than two tires herking. Two spinning tires are both pushing. Jerking tires, one's pushing and the other's stopping, and you ain't goin' anywhere.
    The electronic stuff does its best work in situations where one wheel is low traction and the other is not.
    If everything is low traction, better to lock the ass, leave the front open, and key up the throttle. Momentum FTW.
  6. Oct 2, 2012 at 7:46 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Don't you mean ATRAC. :cool:
  7. Oct 2, 2012 at 7:48 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Depending on the terrain you might want to hit the RSCA OFF switch.
  8. Oct 2, 2012 at 8:05 PM
    jandrews
  9. Oct 2, 2012 at 8:32 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    IBTD
    InBeforeTheDerp..
  10. Oct 2, 2012 at 8:49 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    This is what i was thinking too, aside from all the electronic traction control stuff. I usually turn that off as soon as i get on the trail.
  11. Oct 2, 2012 at 9:24 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    What are driving aids? :D ATRAC? Never heard of it.
  12. Oct 3, 2012 at 9:49 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    We don't need no stinkin driver aids...
    Turn of RSCA as soon as you hit the dirt, rollover control for idiots, no good off road.
    The rest, just play around and find what's working best for that terain.
  13. Oct 3, 2012 at 9:54 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Rollover control? Was that optional for 2012? [​IMG]
  14. Oct 3, 2012 at 10:05 AM
    Gearheadesw
    Davenport Fl
    opps, don't want them air bags going off in off camber situations. These fucking buttons are so unintuitive to use, am going to rip them out add a lever and lockers
  15. Oct 3, 2012 at 12:30 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Hit the dirt, hold the Trac-Control button for 3 seconds at a dead stop, keep it in derprunner mode, shift down to 2, and mash the go-pedal out of a turn while moving the steering wheel from 10:00 to 2:00. You'll understand once you try it.
