What else do i need?
Discussion in 'Suspension' started by MAG GRY TACO15, Oct 1, 2018.
  1. Oct 1, 2018 at 12:33 PM
    MAG GRY TACO15
    MAG GRY TACO15 [OP] Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Just ordered 5100's for all 4 corners, 885 front springs, a 1/4 top plate spacer,(2) kyb SM5640 top mount kit.
    Is the only thing I need now is the aal for rear and alignment? Or is there something obvious that I'm forgetting for my 2015 dcsb 4x4?
  2. Oct 1, 2018 at 12:34 PM
    Manbun525
    Manbun525 Well-Known Member
    Jake
    Phoenix, AZ
    2017 Inferno Tacoma TRD OR DCLB
    5100@4 888 OME with HS 3 AAL Avid Sliders Prinsu Rack 285/75/16 Cooper Pros
    Should be good, anything else is mostly optional, like UCAs
  3. Oct 1, 2018 at 12:41 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    It's recommended you replace your u-bolts, as they stretch when they are torqued down. Your factory ones also may be too short with your aal.
  4. Oct 1, 2018 at 12:46 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Trying to stay with stock UCA if possible which is why I only went with 885's so hopefully they won't be needed. If they are I guess I'll be starting a new thread about trying to find best bang for the buck ones haha.
  5. Oct 1, 2018 at 12:48 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I have 3+1 leafs now and was planning on just using a single leaf aal and not a 3 leaf progress so I hope I can still use the stock ones. I know it's mostly recommend to not reuse a u bolt but I have also reused mine with thousands of issue free miles on multiple lifted vehicles. (not saying it's right so maybe since this is the newest and nicest vehicle I've ever owned I'll gather up some extra shekels and get new ones haha
  6. Oct 1, 2018 at 12:49 PM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    I needed UCA's with 885's, but it seems to be hit or miss whether or not you need them or not. You'll know if you need them.
    Light Racing seem to be the cheapest, and the most popular. You may be able to find a used set on here somewhere, that's what I did. Some sandblasting, painting, and new bushings and they're good as new.
  7. Oct 1, 2018 at 12:52 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    That's a great idea. Off to the marketplace to search for used UCA's haha.
  8. Oct 1, 2018 at 12:55 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I’d wait. I had that same setup and didn’t need UCAs, alignment was good, drivability was good, tire wear was normal.
    Used LR UCAs have no warranty, either.. so up to you if that’s the pursuit. Even if they’re brand new.. they’re only warranted to the original purchaser.
    If you want a new set.. PM me. I have a vendor with prices you won’t find anywhere else.
    Here’s a link to my closed group buy. I won’t lead you astray.
    https://www.tacomaworld.com/threads/closed-spc-lr-upper-control-arm-group-buy.485771/
  9. Oct 1, 2018 at 12:58 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    You should be good to go then :thumbsup:. I needed longer u-bolts when I had 2+1 leafs and added an AAL because I only had about a quarter inch of thread exposed to try to fit the nut on.
  10. Oct 1, 2018 at 12:59 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I'll hold off til I know they are something absolutely needed. I have a pretty good alignment place I've used before to align an IFS truck with 4 inches of lift and another solid axled 5 inch lifted rig too. So hopefully they can get it taken car of without new UCA's. If I do need them i'll for sure hit you up and see what we can come up with. Thanks!
  11. Oct 1, 2018 at 1:02 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Approaching 2.5" of lift or more, it is HIGHLY recommended that you get aftermarket UCAs. Unless you want to wander on the highway or be in that alignment shop all the time.
    Buy once cry once. Might as well do it while it's apart already. My .02.
    Manbun525 likes this.
  12. Oct 2, 2018 at 5:19 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    As far as a warranty goes on UCA's: It's a piece of metal with bushings in it. As long as whoever had them before you wasn't jumping the truck they'll probably be fine.
    When I put in the single leaf AAL I had the U bolts were not long enough. It was more than a quarter inch, but I wasn't going to leave it like that.
  13. Oct 2, 2018 at 6:29 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I took a gander at mine last night. It didn't look like I had a whole lot of room to work with. How thick is a single aal that provides 1.5-2 inches of lift? And should i got with the 1.5 or 2 inch. Deaver aal is a 1.5-2 and wheelers has 2 different aal that are a.5 and 2 inch lift.
    And since this is for the stock application, i need ubolts that are squared and not rounded. Rounded would be for a u bolt flip kit set up correct?
    These should be all i need correct?
    https://www.tacomaworld.com/threads/icon-ubolts.569670/#post-18827120
