what else do i need?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jake slatnick, Nov 29, 2009.
  1. Nov 29, 2009 at 5:45 PM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    i just bought some pro comp off roading lights but im not sure what wiring harness and everything else i need to mount them on my stock bumper
    heres a link to the ones i ordered: (i ordered four)
    $20 Pro Comp 55 Watt 5" Fluted Light (Stainless) - 9561 Offroad Racing, Fog & Driving Lightshttp://www.4wheelparts.com/Lights-L...c=14&t_s=448&t_pt=4242&t_pl=1849&t_pn=EXP9561
    how would i mount them to my bumper? would it be better to drill holes in my stock bumper or get some kind of bracket that will mount to the frame?
    thanks
  2. Nov 29, 2009 at 6:36 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    nobody knows?
  3. Nov 29, 2009 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You would have to mount them to something solid. the stock bumper is plastic. If you were to add some steel plate to the underside of the bumper, that might work.
