What else makes you FAP?
Discussion in 'Off-Topic Discussion' started by FlawedXJ, Mar 30, 2009.
  1. Mar 31, 2009 at 8:09 PM
    #81
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    kTm rc8 1190
    and of course R version
    Engine type 2-cylinder, 4-stroke, V 75°
    Displacement 1195 cc
    Bore x stroke 105 x 69 mm (4.13 x 2.72")
    Performance (homologated) 121 kW @ 10250 rpm
    Max. torque 123 Nm @ 8000 rpm
    Compression ratio 13.5:1
    Starter/Battery Electric Starter/12 V 11.2 Ah
    Transmission 6 gears, dog clutch engagement
    Fuel Mixture Generation Keihin EFI (throttle body 52 mm (2.05"))
    Control 4 V/DOHC
    Lubrication Pressure lubrication with 3 Eaton pumps
    Engine lubrication Motorex, SAE 10W-50
    Primary drive 40:76
    Final drive 17:37
    Cooling Liquid cooled
    Clutch Wet multi-disc clutch, operated hydraulically
    Motor Management Keihin EMS
    CHASSIS
    Frame Chromium-Molybdenum trellis frame, powder-coated
    Subframe Aluminium
    Handlebar Aluminium stump handlebar
    Front suspension WP-USD Ø 43 mm
    Rear suspension WP-Monoshock
    Suspension travel front/rear 120/120 mm (4.7 / 4.7")
    Front brake 2 x Brembo four piston, radially bolted caliper, brake disc 320 mm (12.6")
    Rear brake Brembo two piston, fixed caliper, brake disc 220 mm (8.66")
    Rims, front/rear Cast aluminium wheels 3.5 x 17"; 6 x 17"
    Tires, front/rear 120/70 ZR 17; 190/55 ZR 17
    Chain X-ring 5/8 x 5/16"
    Main silencer Stainless steel underfloor silencer with regulated catalytic converter
    Steering head angle 66.7°
    Trail 97 mm (3.82")
    Wheel base 1425 mm (56.10")
    Ground clearance (unloaded) 110 mm (4.33")
    Seat height 805/825 mm (31.69/32.48")
    Tank capacity approx. 16.5 liters/3.5 liters reserve (4.36/0.92 gal)
    Weight (no fuel) approx. 182 kg (405.23 lbs)
  2. Mar 31, 2009 at 8:57 PM
    #82
    FlawedXJ
    FlawedXJ [OP] mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    omg i just fapped
  3. Mar 31, 2009 at 10:04 PM
    #83
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    Screw sport bikes, anyone can go fast in a straight line
    These are a lot more fun
  4. Mar 31, 2009 at 10:32 PM
    #84
    tacomajason
    tacomajason the anti mpg
    Arkansas
    09 ssm ac oc 6mt 4wd
    stock (for now)
  5. Mar 31, 2009 at 11:18 PM
    #85
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Oh yeah, Ken Block's Subie get's me too:
  6. Apr 1, 2009 at 9:03 AM
    #86
    98tacoma27
    Ben
    Not Beech Creek
    But what about the specs on the bike?
