What engineering discipline are you in?
Discussion in 'Jobs & Careers' started by frizbal, Apr 23, 2015.
What engineering degree did you achieve?
  1. Electrical
    13.8%
  2. Civil/Environmental
    13.8%
  3. Mechanical
    37.0%
  4. Chemical
    2.9%
  5. Industrial
    2.5%
  6. Aerospace
    5.7%
  7. Computer
    11.8%
  8. Petroleum
    1.1%
  9. Structural
    2.5%
  10. Other
    8.8%
  1. May 7, 2025 at 12:03 PM
    #521
    JKO1998
    JKO1998 Well-Known Member
    Utah
    No PE in my company to work under so I guess it doesn't really matter
  2. May 9, 2025 at 10:28 AM
    #522
    Finbox
    Finbox Well-Known Member
    Tim
    15' access cab 4x4
    A Civil PE allow you to work for your self. Depends on what field you work in. Last I looked the wages are about the same after the PE. The masters delays 2 years of experience. I would say go work and see if or what you like to do, then see if a masters is needed or desired. Work is different than school.
  3. May 9, 2025 at 12:20 PM
    #523
    JKO1998
    Utah
    I've been working full time while getting my masters online, just looking at next steps, Utah requires working under a PE to get your PE, haven't looked at the requirements in other states
  4. May 9, 2025 at 12:23 PM
    #524
    marcamos
    marcamos Well-Known Member
    Marc
    Beverly, Massachusetts
    2021 Off Road 6MT
    I build websites for a living (specifically, I write HTML, CSS, and JavaScript … for about 20 years now).
  5. May 9, 2025 at 12:51 PM
    #525
    Finbox
    Tim
    15' access cab 4x4
    Good, so you know the work you are getting into.
    In California you need 2 year on the job experience under a PE and get several letters of recommendation to take the PE exam, last time I looked 20 years ago.
  6. May 9, 2025 at 12:59 PM
    #526
    JKO1998
    Utah
    Basically the same here, but 5 years and the test of course
  7. May 9, 2025 at 8:51 PM
    #527
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    CA PE requires 6 years of experience but education counts as four. CA Civil PE here who took advantage of that requirement.
    The experience part not the education.
