What exactly does a bumpstop do for ride comfort? Anything?? Sorry if a dumb question(problm fixed)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CLVol1255, Dec 1, 2018.
  1. Dec 1, 2018 at 12:09 PM
    CLVol1255
    CLVol1255 [OP] Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    I recently did the 5100 Bilstein front and rear .25 inch driver side spacer 888 OME springs and a deaver AAL. I’m very happy with the outcome and overall look upgrade I got from it. Sometimes though when riding on normal highway and roads man you can really really feel the ass end when it rolls over something other than smooth pavement. I mean it really jars the hell out of the backend and honestly feels like it’s lighter on the wheels in the rear than it should be. I’m also running factory tires 265 65 17 size wise but I did put toyo open country AT2s on it. I didn’t even think about possibly getting bigger tires with my lift being the noob I am. Would a bump stop improve this or what is something I could do to improve this without getting a whole new leaf set. Preferably under $200. Thanks
    TXpro4X4 likes this.
  2. Dec 1, 2018 at 12:11 PM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    Bump stops prevent your shock from bottoming out or potentially collapsing to the point of failure. Some more expensive ones provide more cushion than others, but they are not designed to absorb shock like shocks are.
  3. Dec 1, 2018 at 12:12 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Adjust tire pressure
  4. Dec 1, 2018 at 12:13 PM
    SpeySquatch
    2016 TRD OR DCSB
  5. Dec 1, 2018 at 12:20 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Plastics Guy likes this.
  6. Dec 1, 2018 at 12:22 PM
    SpeySquatch
    2016 TRD OR DCSB
    If you do get them have your front wheels off the ground and lube the snot out of the fronts with WD-40 to soak the threads and use a pipe wrench to get them loose. The new ones bolt right in
  7. Dec 1, 2018 at 12:23 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    Thank you sir!
    Boatbldr likes this.
  8. Dec 1, 2018 at 12:28 PM
    Arailt
    Dallas, TX
    2019 GX460
    Bump stops aren't going to solve your problem. If your experiencing a stiff ride on pavement after installing a lift, it's because the AAL and shock combo has simply stiffened up the ride and you're either not used to it yet or the combo was designed to carry a constant load and it's just too stiff for your application. Is the AAL you installed a single leaf? Those have a much stiffer ride than a progressive/multi-leaf AAL will.
    Unless you're hauling a significant amount of weight that would cause your rear end to be bottoming out on the highway, new and/or better bump stops will do nothing.
  9. Dec 1, 2018 at 12:33 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    ummmm. air bump stops are a tiny shock
    check out the wheelers super bumpstops. they are made of foam and feel like your landing on a cloud of titties
    drizzoh, Parker315, tonered and 5 others like this.
  10. Dec 1, 2018 at 12:35 PM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Bump stops are for people who don't run Bilstein 8112's...
    JustMeMyselfAndI, whatstcp and Arailt like this.
  11. Dec 1, 2018 at 12:38 PM
    Arailt
    Dallas, TX
    2019 GX460
    OP is experiencing a stiff ride in his rear end on pavement after an AAL lift. Better bump stops will not fix that. And while air bump stops are designed to provide more cushion should they be needed, they are not designed to absorb constant shock like actual shocks are.
    Plastics Guy, Stryker420 and na8rboy like this.
  12. Dec 1, 2018 at 12:43 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    :thumbsup::thumbsup::thumbsup: but with my factory leaf springs and 300lbs in the back. Mine would bottom out on the bump stops.
    thats with the 4 leaf pack for 2nd gen
  13. Dec 1, 2018 at 12:45 PM
    SpeySquatch
    2016 TRD OR DCSB
    This is tru, plus after a month the suspension should settle. Valving of digressive vs progressive shocks makes more stiffness too
    Arailt[QUOTED] likes this.
  14. Dec 1, 2018 at 12:45 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    I have noticed that when I have something in the bed with a little bit of weight to it the truck seems to ride much much better
    bshammer0, SpeySquatch and Arailt like this.
  15. Dec 1, 2018 at 12:46 PM
    SpeySquatch
    2016 TRD OR DCSB
    Of course
    tonered and Arailt like this.
  16. Dec 1, 2018 at 12:51 PM
    Arailt
    Dallas, TX
    2019 GX460
    Haha, that's the truth! My 09 with the recall leafs squatted more than it did with my original 3 leaf pack on. Before I put the wheeler's 3-leaf AAL in, it would hit the bump stops if I hit a strong head wind.
    mynewtoy[QUOTED] likes this.
  17. Dec 1, 2018 at 1:14 PM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    Check out the sexy ass 3rd gen featured in the Tacoma section. Looks familiar. :bananadance:
    Parker315 and Plastics Guy like this.
  18. Dec 1, 2018 at 1:17 PM
    SpeySquatch
    2016 TRD OR DCSB
    How you like your bumpstops? Notice a difference?
  19. Dec 1, 2018 at 1:25 PM
    chucklefunkk
    So. AZ
    2016 TRD OR
    A lot of us AZ folks got to be part of the testing and evaluation. I removed my Wheelers bumps and installed Durobumps and I love them. They're designed and manufactured by a Toyota driver and forum member @Plastics Guy. My front end was getting airborne during testing and if it wasn't for the picture proof I wouldn't have known. Takes the jolt out of bottoming out.
    Plastics Guy, DeltaBravo and mynewtoy like this.
  20. Dec 1, 2018 at 1:27 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Astute observation. Can confirm titties
    tonered, tcjacado, Gator352 and 2 others like this.
