What exactly does switching to H4 do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dansnare, Oct 20, 2016.
  1. Oct 20, 2016 at 10:11 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I was careful not to say anything but spinning - but in 2WD if one tire loses traction neither tire can push the truck and you are stuck. I'm speaking from a strictly mechanical standpoint here, lockers and traction control schemes can change things.
  2. Oct 20, 2016 at 10:13 AM
    tgear.shead
    tgear.shead Well-Known Member
    While you can have one tire spinning and the other stationary, he is STILL correct that neither is getting [significant] power. It doesn't take much power to spin a wheel that has no traction.
  3. Oct 20, 2016 at 10:18 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If you go out stomp the gas, youre only gonna get one tires that smokes.
  4. Oct 20, 2016 at 10:19 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Wow, TW is full of bullshit, I mean experts.
    mikesarge, Benzdriver81 and IronPeak like this.
  5. Oct 20, 2016 at 10:23 AM
    andrew61987
    This doesn't really prove anything relevant to the discussion. If you stomp the gas and smoke one tire the truck is still going to accelerate forward with equal power from both wheels. Both the spinning tire and non spinning tire are propelling the truck with equal force in this case. The non spinning tire can only propel the truck with as much force as the kinetic friction coefficient of the spinning, smoking tire will allow.
    tgear.shead likes this.
  6. Oct 20, 2016 at 10:24 AM
    tgear.shead
    And yet they are still receiving EQUAL power.
  7. Oct 20, 2016 at 10:26 AM
    moondeath
    Pa, Gardners
    I see what your saying with equal power. I was thrown off by your original statment about them not being open diffs. I thought you were saying they were locked.
  8. Oct 20, 2016 at 10:42 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    power is going the route of least resistance. If your in 2wd and your right rear is in the air. your right rear is going to spin and your not going anywhere. Auto - LSD then comes into play, applies brakes to right rear, dispersing power equally over rear axle
    moondeath likes this.
  9. Oct 20, 2016 at 10:54 AM
    tgear.shead
    Have you not bothered to read? If your right rear is in the air, then only NEGLIGIBLE power is being delivered to it (because it doesn't take much to make it spin), and an EQUAL (still negligible) power is going to the one with traction.
    Your explanation about the brakes is also indicative of misunderstanding. It doesn't "redirect" **ANYTHING**. It just holds the wheel so that BOTH can be delivered ALL the power.
    On an open differential, BOTH outputs ALWAYS receive EXACTLY the same power!
    If you don't believe me, try this little experiment;
    Get yourself a piano board. That's what we call a flat board with 4 wheels that you use to move a piano.
    Get a JACK STAND.
    Position the jack stand ON the piano board, under the RIGHT REAR axle, at a height just enough to keep the wheel off the ground.
    Get in the car, release the brake, put it in first gear, and GIVE IT, briefly, with the wheel in the air. Careful not go go over the red line.
    What YOU THINK you will observe: wheel spinning.
    What you WILL observe: it will move forward. A bit, and very weakly. The forward motion will occur WHILE the raised wheel is accelerating -- since it doesn't take any power to sustain a constant speed. But WHILE that wheel is accelerating, it will deliver some power to the wheel on the ground, and you will get some forward motion.
  10. Oct 20, 2016 at 11:05 AM
    moondeath
    Pa, Gardners
    Lol. No need to be a dick. Hes just commenting. I think there is some misunderstanding from both sides of the use of 'power' being distributed. Yes, both tires receive equal power. But for explanation purposes, which toyota uses the same explanation for auto lsd and ATRAC, is that the brakes are applied to the slipping side to allow the tire with traction to push the vehicle.
    VangaSTL likes this.
  11. Oct 20, 2016 at 11:07 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Your confusing open differential with locked differential. A locked differential both wheels have the same amount of power all the time. With open differential the power goes to the wheel with least resistance.
    fast forward to 2:10
    https://www.youtube.com/watch?v=gIGvhvOhLHU
  12. Oct 20, 2016 at 11:08 AM
    gottaToy
    JJ
    1985 Moped
    @tgear.shead You're a fucking idiot! Watch the video posted and see that YOU ARE WRONG!
  13. Oct 20, 2016 at 11:18 AM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    Thats the plan for now once i have the monies. just thought i would ask in case there was something out there i did not know about.
  14. Oct 20, 2016 at 11:35 AM
    tgear.shead
    I am not confusing anything. You are.
    Like I said, when one wheel is in the air, NEGLIGIBLE power is delivered to BOTH. That is why you don't move.
  15. Oct 20, 2016 at 11:41 AM
    #35
    tgear.shead
    Yelling like a FUCKING ASSHOLE doesn't make you right.
    As far as the VIDEO goes... wow, you believe everything that you see on youtube? First off, the video is downright WRONG. I don't know if that is a result of whoever made it actually not understanding, or if it was a bad attempt to oversimplify it for simpletons who CAN'T understand how it works.
    An open differential ALWAYS delivers EXACTLY the same power to ALL outputs.
    When one output doesn't have enough traction to hold the power, it slips. When it slips, you (the driver) regulate the power output by reducing throttle to prevent engine damage due to overrevving. Very little power is being generated, very little power is being delivered -- to ALL of the outputs.
  16. Oct 20, 2016 at 11:55 AM
    #36
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Let's try this 1 MORE time. Fast Forward to 3:10
    https://www.youtube.com/watch?v=WzMiGtUw0cs
  17. Oct 20, 2016 at 11:58 AM
    #37
    tgear.shead
    How do you think it helps you to post links to videos that YOU clearly DO NOT UNDERSTAND?
  18. Oct 20, 2016 at 12:00 PM
    #38
    gottaToy
    JJ
    1985 Moped
    You're a douche and are talking shit. You need some meds or something.
  19. Oct 20, 2016 at 12:02 PM
    #39
    tgear.shead
    I will refer you to this;
  20. Oct 20, 2016 at 12:02 PM
    #40
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Please enlighten me then because the only thing you've said is that both wheel are getting equal amount of power in an open differential which is terribly wrong. So instead of cussing about how your right and everyone else is wrong why don't you back up your claims and show us. Just because you know how to use the caps lock doesn't mean your right.
