What exactly does switching to H4 do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dansnare, Oct 20, 2016.
  1. Oct 20, 2016 at 1:30 PM
    #81
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    OP, just open your diffs, and take a welder and weld everything together. At'll fix it.
    VangaSTL likes this.
  2. Oct 20, 2016 at 1:31 PM
    #82
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    ajm likes this.
  3. Oct 20, 2016 at 1:32 PM
    #83
    Roll Tide
    Q
    01 T4R
    But if one wheel is spinning, and the other one isn't, then all the power is going to air AROUND the wheel that is spinning.
    mikesarge likes this.
  4. Oct 20, 2016 at 1:35 PM
    #84
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    I sure hope he tells them to use some gear lube to avoid getting splinters in their peckers. OH, I wonder if he tells them that's what "wood peckers" are, not a bird?
  5. Oct 20, 2016 at 1:36 PM
    #85
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I didn't see it mentioned but I think up to 07 or 08, the TRD models came with a clutch based rear limited slip diff. All the newer trucks use the rear brakes to simulate limited slip (so the rear diff is as open as can be).
  6. Oct 20, 2016 at 1:41 PM
    #86
    Roll Tide
    Q
    01 T4R
    So, if the rear right tire is the primary drive tire, and it is spinning freely, with the accelerator pedal to the floor, what is the left front steer tire doing?
  7. Oct 20, 2016 at 1:43 PM
    #87
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    2nd gens have auto lsd after something like 08-09 (not sure which year changed), which is simulated lsd through the brake system.
  8. Oct 20, 2016 at 1:43 PM
    #88
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    You mean the LSDs from 07 or 08 and up are simulated LSDs? I thought only the 3rd Gens had the simulated LSDs. Just trying to clarify
  9. Oct 20, 2016 at 1:43 PM
    #89
    2015WhiteOR
    Gainesville TX
    If my memory is any good then I believe so. The "older" 2nd gens actually have physical clutch packs in the rear diff. The "newer" 2nd gens have a traction mode called "AUTO LSD" that applies brake pressure to the rear wheels to gain traction.
  10. Oct 20, 2016 at 1:47 PM
    #90
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    If one wheel is jacked up and spinning and the other is stationary neither wheel is transferring any power anywhere, except for the amount of power it takes to stir the air up around the tire etc which i'm ignoring.
    Lower that wheel and both wheels grip and get power. My both or neither is definitely correct in our context.
  11. Oct 20, 2016 at 1:49 PM
    #91
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Found this from 2010. I thought they were all mechanical. Did they switch when they did the facelift in 2012?
  12. Oct 20, 2016 at 1:52 PM
    #92
    moondeath
    Pa, Gardners
    No, they switched earlier because of traction control devices being introduced.
  13. Oct 20, 2016 at 1:55 PM
    #93
    andrew61987
    Don't think about energy "consumed" by a wheel, think about energy "transferred through" a wheel. The energy transferred for our purposes here is energy that goes to the ground, moving the truck forward. If one wheel is spinning and the other is stationary and the truck is holding still, no power is being transferred by either tire because the truck isn't moving.
    We know this usually isn't the case, because there's friction and heat even when doing a burnout. If you stomp the gas and one wheel spins like crazy and the other doesn't, you're still getting equal power transfer through both wheels. It's not as much as it would be if you weren't spinning a tire, but it's still equal.
  14. Oct 20, 2016 at 2:03 PM
    #94
    wildjester
    wildjester Member
    Omaha, NE
    07 Tacoma 4x4 4.0L
  15. Oct 20, 2016 at 2:03 PM
    #95
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    If there's a skeeter on your peter, whack it off
  16. Oct 20, 2016 at 2:03 PM
    #96
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    When you turn the 4 wheel drive knob, a negative pressure valve off the manifold opens and accutuates the auto hubs in the front driveline. Now you're in 4 wherl drive. Then all the differential action takes place and off you go.
  17. Oct 20, 2016 at 2:07 PM
    #97
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    The issue that is confusing you is this thread of insanity very early on started using "power" when it should have been using "torque". An open diff delivers equal *torque* to each wheel at all times. Not power.
    So go back through all the ridiculousness and when someone says "equal power" change that to "equal torque" and it will be easier to see why everyone is talking past each other and misunderstanding.
    Now to hit the unsubscribe button as fast as possible...
  18. Oct 20, 2016 at 2:09 PM
    #98
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Good thing i'm locked front and rear, this thread is a shit show
  19. Oct 20, 2016 at 2:13 PM
    #99
    CedarPark
    Dylan
    Cedar Park, TX
    Ok ladies and gents chill your shit.
    I have jack stands and jacks ready. I have a selectable in the rear and an Aussie up front. What am I proving?
    ajm likes this.
  20. Oct 20, 2016 at 2:13 PM
    #100
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
