What exactly does switching to H4 do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dansnare, Oct 20, 2016.
  1. Oct 20, 2016 at 2:17 PM
    #101
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    That life did indeed originate in a murky primordial puddle of ooze.
    ecgreen likes this.
  2. Oct 20, 2016 at 2:18 PM
    #102
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    Idk if I can do that and not get banned
    ajm[QUOTED] likes this.
  3. Oct 20, 2016 at 2:19 PM
    #103
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Is that what you were trying to say, @tgear.shead???
  4. Oct 20, 2016 at 2:21 PM
    #104
    ajm
    Anthony
    AZ
    1996 4x4
    I retract my request for said proof and deeply regret any implications or inferences contained therein.
  5. Oct 20, 2016 at 2:43 PM
    #105
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    :rofl::rofl::rofl:
  6. Oct 20, 2016 at 3:36 PM
    #106
    Dansnare
    Dansnare [OP] Well-Known Member
    2013 T/X Baja
    Holy shit!!! What the hell did I do????
  7. Oct 20, 2016 at 3:44 PM
    #107
    Dansnare
    2013 T/X Baja
    So . . . actually my question was a little more basic than all of this (although I do appreciate the effort). I really just wanted to know what does switching from H2 to H4 actually do. Does it just engage the transfer case or more than that? What I am hearing is that on the Tacoma you've got two open differentials and a transfer case. So all H4 does is engage the transfer case to send power to the front, right?
    Dan
  8. Oct 20, 2016 at 3:49 PM
    #108
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    It engages the chain drive in the transfer case (which sends power to the front driveshaft) and also engages the automatic differential disconnect (ADD) which allows the front driveshaft to send power to the wheels.
  9. Oct 20, 2016 at 3:53 PM
    #109
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Benzdriver81 likes this.
  10. Oct 20, 2016 at 3:59 PM
    #110
    Dansnare
    2013 T/X Baja
    Cool. Thanks.
    Dan
  11. Oct 20, 2016 at 4:19 PM
    #111
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    42 years of driving 4wds....17 different trucks, 5 Toyota's, 4 of them Tacoma's. Probably 20,000 miles of off road driving over the years.
    It's all been a waste of time and money.
    This thread has enlightened me as to the error of my ways.
    It's all an illusion........
  12. Oct 20, 2016 at 4:35 PM
    #112
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    damn that's 10 minutes lost but amusing.i bet that guy cant hand figure mileage either.
  13. Oct 20, 2016 at 4:56 PM
    #113
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Someone got triggered. Par for the course here. Not your fault :)
    Dansnare[QUOTED][OP] likes this.
  14. Oct 20, 2016 at 6:12 PM
    #114
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    Sooo what does the switch do :boink::wave::rofl:
  15. Oct 20, 2016 at 6:42 PM
    #115
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    So much ignorance and ego. Holy crap.
  16. Oct 22, 2016 at 4:22 AM
    #116
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Everything is already turning in the drive train, when the knob turns, the hub's engage and now front wheels have power. That's all, no engaging chains, gears, just the hub's in the front axles.
  17. Oct 22, 2016 at 1:25 PM
    #117
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Wrong. Nothing moves in the hubs. There is a axle disconnect on the passenger side of the front diff. And there is a chain that drives the front output of the transfer case. Everything is not already moving
  18. Jan 8, 2017 at 12:49 PM
    #118
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    do any of you guys know if there's any kind of limited-slip in the transfer case? or if it's open? Meaning that the Front and Rear axels are NOT at a fixed power ratio? I know on wranglers they're fixed at 50%/50%, so you can't drive in 4H too much because it'll strain the transfer case when it wants to put more power to the front or rear axel depending where the strain is.
    Just wanted to clear up wether our Tacomas have that same 50/50 fixed split, or if they can shift power front-to-back, making it ok to drive in 4H long distances.
    And is it the same 4WD system in all the Tacoma trims, despite that some trims come with the locking rear diff?
  19. Jan 10, 2017 at 5:08 AM
    #119
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    There's no diff in the transfer case frontfront output and rear output are locked together. Also all trim levels are the same other than trd Offroad and trd pro have rear diff lock and atrac.
    doublethebass likes this.
  20. Jan 10, 2017 at 7:13 AM
    #120
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    horry shi
