What factory parts will I need? Spacers - Eibach Lift Coils.
Discussion in '1st Gen. Tacomas (1995-2004)' started by brandnewcolony, Aug 9, 2011.
  1. Aug 9, 2011 at 8:54 PM
    brandnewcolony
    brandnewcolony [OP] Well-Known Member
    Fort Worth, Texas
    2017 Tacoma TRD Pro SW
    Hey guys, well I finally saved enough money to pull the trigger on a new suspension set-up. What factory parts, if any, will I need to go from this spacer lift to Eibach lift coils mounted on 5100's set a 0? I just wanna make sure I have all the parts needed to swap out the front suspension without any unexpected problems. Thanks for your help, Matt
  2. Aug 9, 2011 at 9:05 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    How are the bushings? That would be the only thing I could think of...personally.
  3. Aug 9, 2011 at 9:18 PM
    brandnewcolony
    Fort Worth, Texas
    The Bilstein 5100's I'll be getting should come with new bushings. If not those will need to be on my list. I want to use all new parts if I can. Thanks for the help, any other parts I need?
  4. Aug 9, 2011 at 9:23 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    depending on where you bought your set up, they should come with instructions which will include what will be taken from your stock set up. Keep everything, dispose nothing. [Except for those lift spacers.]
  5. Aug 9, 2011 at 9:27 PM
    brandnewcolony
    Fort Worth, Texas
    I'll be buying the 5100's from Downsouth. Thanks for the advice I appreciat it.
  6. Aug 9, 2011 at 9:31 PM
    brandnewcolony
    Fort Worth, Texas
    I bought this Tacoma with the spacer front lift. So since I'm not going exactly from a stock suspension set-up, I figured I would need any factory parts that the previous owner didn't use or throughout when he did the spacer lift.
  7. Aug 9, 2011 at 10:17 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Your gonna need the Top plates on there "the ones with the studs".
  8. Aug 10, 2011 at 1:29 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    X2
  9. Aug 10, 2011 at 6:36 AM
    brandnewcolony
    Fort Worth, Texas
    So I can use the top plates that are mounted on the spacers currently, with the eibach/ 5100 set up?
  10. Aug 10, 2011 at 8:31 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea it looks like your missing the top plate..
    should have something like this
    the small black plate thats on top of the coils.
  11. Aug 10, 2011 at 9:14 AM
    brandnewcolony
    Fort Worth, Texas
    Thanks for all the help guys! Could I get the top plate with the rubber gasket from my local Toyota parts Department?? Is that all the parts I will need to assemble the Eibach's and 5100's together so that I can just take the spacer, stock coil and shock out and directly replace it with the new assembly??
  12. Aug 10, 2011 at 9:17 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think you can get them at your local dealer. they aren't cheap so be prepared. And yea, new bushings are about all ya need. The spring compressor too to put the together of course and make sure the 5100s are set at 0''. other then that, thats pretty much all ya need
  13. Aug 10, 2011 at 9:28 AM
    brandnewcolony
    Fort Worth, Texas
    Hey thanks bro, I will be calling Toyota Parts here shortly. I hope they don't put too much of a dent in my wallet :). I've been saving up for quite a while to get the main parts for my lift.
  14. Aug 10, 2011 at 9:36 AM
    kmok
    Kyle
    Columbus, Ohio
    Depending on how much the top plates cost from toyota, I would look at these. You won't need the top plates with that and I believe it comes fully assembled and is easily adjustable.
  15. Aug 10, 2011 at 9:47 AM
    brandnewcolony
    Fort Worth, Texas
    Called Toyota and the the top plate mounts is $60.00 a piece, ouch! For the pair ill be paying almost as much as for the Eibach's coils.
  16. Aug 10, 2011 at 10:05 AM
    brandnewcolony
    Fort Worth, Texas
    I was actually considering those Toytec/ Bilstein coilovers. I think I might save a couple hundred however going with the Eibach/5100 set up and paying for the factory top plates from Toyota.
  17. Aug 10, 2011 at 10:12 AM
    kmok
    Kyle
    Columbus, Ohio
    Yeah that's true, you just won't have the adjustability of the coilover.
  18. Aug 10, 2011 at 10:13 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    You can do a Google search for the top plate and get them a lot cheaper than from Toyota. Wheelers has them I think.
  19. Aug 10, 2011 at 10:15 AM
    kmok
    Kyle
    Columbus, Ohio
  20. Aug 10, 2011 at 10:27 AM
    brandnewcolony
    Fort Worth, Texas
    Thanks kmok and TMW! On the link you posted kmok I would need the:
    *Strut Top Plate/Upper Coil Support
    and
    *Polyurethane Coil Isolator Pair???
