What filter is this?
Discussion in 'Performance and Tuning' started by StaticFilter, Jul 14, 2010.
  1. Jul 14, 2010 at 3:14 PM
    StaticFilter
    StaticFilter [OP] Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    I need to figure out what kind of filter this is so I can clean it. It's a foam filter inside a cage, dont think it comes apart... Think I'd be safe to use the gasoline cleaning method on this thing?l_dba8bd008a8749efb4f667a7a26cfd25_dd3fbdd9706475cf13b900161e396296ec06f75f.png
  2. Jul 14, 2010 at 3:25 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    what did it come off of? dirtbike?
  3. Jul 14, 2010 at 3:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    looks like a "true flow" filter to me.
  4. Jul 14, 2010 at 3:44 PM
    StaticFilter
    Cedar Hills, UT
    Sorry I should have been more specific, it is a True Flow filter but I have never seen one like it nor can I finbd one like it on the net, not sure if the true flow cleaning kit will work with it due to it being in a cage...
  5. Jul 14, 2010 at 3:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    does it come apart at all?? if not......im not too sure. may wanna try a k and n cleaning kit, or just soap and water. but there has to be a way for the foam cover to come out off the filter.
  6. Jul 14, 2010 at 3:51 PM
    SoCalBlack08
    SoCalBlack08 Well-Known Member
    CA
    08 PreRunner DC
    just rinse it from the inside out and if u notice a color change from red it might need to be ioled( like the k&n)
  7. Jul 14, 2010 at 3:58 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    TrueFlow makes a cleaning kit like the K&N. Spray the outside of the filter w/ the cleaning solution. Let it soak for about 10 mins or so and rinse. Use a garden hose to spray from the inside out, that way the dirt etc. gets pushed back out instead getting pushed back into the filter.
  8. Jul 14, 2010 at 4:04 PM
    StaticFilter
    Cedar Hills, UT
    Doesn't come apart, there's a cage on the inside too, except the end of the filter only has a cage on the outside. If I garden hose it, how long will it need to sit before i can drive again since i cant wring it out?
  9. Jul 14, 2010 at 4:11 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I would say 24 hours to make sure the air filter dries out completely... but it depends on how hot or how humid the weather is.
  10. Jul 14, 2010 at 5:34 PM
    StaticFilter
    Cedar Hills, UT
    True Flow is out of biz so I'll never find the cleaning kit now. Decided to go with the hot water/dish soap in a bucket method and just dunk it a thousand times. I've got the filter sitting in the sun, hopefully a few hours will do cuz i dont have 24.
  11. Jul 14, 2010 at 5:36 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    looks like its foam filter
  12. Jul 14, 2010 at 5:37 PM
    TacomaMtnMan
    TacomaMtnMan those who seek fear shall be followed by fear
    Chuck
    Broomfield
    Fox Shox lifted DC 4x4
    3" lift using Fox Shocks Coilover, Total Chaos UCA's. Running: Duratrac 285/70/17 Rear suspension just a 1" block for now. Will have custom rear springs no block. Fox w/ Resi.
    be sure you dont have to oil it... not familiar with true flow... it does look like it was due for a cleaning though. :)
  13. Jul 14, 2010 at 5:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can still find the cleaning kits on ebay.
  14. Jul 14, 2010 at 5:42 PM
    humanoid
    humanoid bite me
    Sunny SoCal
  15. Jul 14, 2010 at 5:43 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    soapy water bucket is prolly best. you can put it on wet it wont hurt anything... make sure its nice and oiled after you wash it.
  16. Jul 14, 2010 at 5:45 PM
    StaticFilter
    Cedar Hills, UT
    Yep already tried there :)
    "Availability:: Currently Unavailable"
    Thanks for the suggestions. It's a foam filter, not gauze, so K&N cleaner wont work. I think it's pretty clean nopw, just need to find a decent Foam Filter oil locally!
  17. Jul 14, 2010 at 5:45 PM
    StaticFilter
    Cedar Hills, UT
    Any suggestions on oil type?
  18. Jul 14, 2010 at 5:47 PM
    Yoytoda
    Roland
    completely stock
    i forget the name its P07104 something or other. i buy it from local dirtbike shop usually 6-8$ a can
  19. Jul 14, 2010 at 5:52 PM
    Yoytoda
    Roland
    completely stock
  20. Jul 14, 2010 at 8:17 PM
    humanoid
    humanoid bite me
    Sunny SoCal
