What Fluid to use for Front/Rear Diff? LS Additives?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rustyfromskowhegan, Jun 20, 2019.
  1. Jun 20, 2019 at 1:51 PM
    rustyfromskowhegan
    rustyfromskowhegan [OP] Well-Known Member
    2013 AC 4x4
    I'm planning on doing fluid changes in my new-to-me (bought in December) 2013 base, 4x4 MT. I'd like to change the front and rear diff, transfer case, and transmission fluids. Truck has just over 70k miles and I'm not sure if these fluids have ever been changed.
    Based on research here I was planning on using redline MT-90 for the manual transmission and transfer case.
    It seems like most folks on here go with Mobil 1 75W-90 fluid for the diffs. My question is do I need LSD additive? From what I've read on here trucks newer than 2008 don't have a LSD, but when I looked up my spec sheet with my VIN number I got this:
    5-Speed Manual Transmission 4WDemand: Part-Time 4x4 Sys w/ 2-speed Electronically Controlled Transfer Case Automatic Limited-Slip Differential
    What type of gear oil should I be using for my front and rear differentials? Do I need something that has LS additives in it?
    I've changed engine oil plenty of times, but this will be my first time changing differential, transmission, and transfer case oil, so I want to make sure I get it right. I'd appreciate any advice or input. Thanks!
  2. Jun 20, 2019 at 2:33 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I just solved a problem that mine encountered by using Car Quest full synthetic and a friction modifier additive. I went back to Valvoline 80W-90 dino and the friction modifier, that stopped the chatter.
    My differential is mechanical. The electronic controlled ones may be different but I would sort of doubt that.
  3. Jun 20, 2019 at 3:08 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    According to pp 458-460 of your Owner's Manual, Front & Rear Diffs require "75W-85 GL-5 or equivalent," MT & Transfer Case require "Gear oil API GL-4 or GL-5 SAE 75W-90." LSD additive is not required, as our "AUTO LSD" relies on the electronic Vehicle Stability Control (VSC), rather than mechanical clutches.
    For convenience, I run Amsoil Severe Gear 75W-90 in all of them. (It's recommended for differentials, manual transmissions and other gear applications requiring GL-5; and can be used in axles where GL-4 is recommended.)
  4. Jun 20, 2019 at 3:08 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
  5. Jun 20, 2019 at 3:39 PM
    rustyfromskowhegan
    2013 AC 4x4
    Thanks for the feedback. Do these trucks come stock with dino or synthetic gear oil in them?
    Also what do you mean when you say "chatter"? I notice sometimes when going over washboard type bumps (welcome to RI) that there's some chatter that seems to come from underneath, but sounds almost more like its coming from the transmission than the differential... seems to go away if I put it in neutral...
  6. Jun 20, 2019 at 3:42 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    NO additive because your differentials are not mechanical limited slip. Only the 2005-2008 Sport had a LSD in the rear.
    However, synthetic gear oil (Mobil 1 75-90, for example) do not need additives even if you had LSD clutches in the diff.
    Norton likes this.
  7. Jun 20, 2019 at 6:39 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    Redline MT-90 works great in the 5 spd manual, I use it in mine. Auto LSD uses the brakes electronically to control wheel spin, and is not a clutch plate type limited slip.
    Some users, and many manufacturers claim synthetic gear oil doesn't need the LSD additive. However, that has never worked for me in any vehicle with clutch plate type limited slip. I tried Mobil-1 75W-90 in a 1998 Dodge, and a 2003 Tundra, and both chattered terribly, and I had to buy LSD additive, and put it in the rear diff after I did the fluid change to stop it. That's been my experience, but yours may vary.
  8. Jun 20, 2019 at 7:30 PM
    NavyGuyAN
    NavyGuyAN Well-Known Member
    Virginia Beach, VA
    2010 Silver Taco 4x4
    Wet Okole Seat covers, Weathertech Floor mats, Blistein 5100's all-around, BFG KO2’s Fumoto Drain valve
    I looked at my manual for my 2010 and the transfer case is the only box that calls for LS gear oil. I just changed all of the fluid in the diffs an x-fer case with mobile 1 75W-90. Only my rear differential is very dirty my transfer case was pretty clean and so was my front dif since I don’t use my four-wheel-drive that often
  9. Jun 24, 2019 at 3:07 PM
    rustyfromskowhegan
    2013 AC 4x4
    Thanks for the feedback all. Sounds like I'm going to go with the redline MT-90 for the transmission and a synthetic (mobil, amsoil, or valvoline) 75w90 for the diffs and transfer case. Hopefully all goes well!
  10. Jun 24, 2019 at 3:59 PM
    David K
    Funny, but both times I changed the three (Front diff, Rear diff, Transfer case), only the rear diff was darkened and looked tired. I do use 4WD a bit but not daily, and the front diff and transfer case were clean, after 30-40 K.
  11. Sep 9, 2023 at 1:55 PM
    Ayoung208
    Ayoung208 Member
    Andrew
    2010 Tacoma TRD Sport DCLB
    Does anyone know if using a gear oil which comes with LSD additive would be harmful to a differential that is not limited slip?
  12. Sep 9, 2023 at 4:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I didn’t hurt mine…….
    Been in there for 40k miles now.
  13. Sep 9, 2023 at 5:08 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Unless things have changed use only GL4 gear-oil in the manual transmission. This does not mean that a container that says: "GL5"/(GL4 compatible) is acceptable in the 2nd-Gen stick transmission. GL5 has a higher sulfur content and will wear out the synchros in short order.
    O'DubhGhaill likes this.
  14. Sep 9, 2023 at 5:13 PM
    TnShooter
    Deogee
    STOCK
    It’s been 4 years since that post.
    I bet he isn’t worried about it now.
    (We all do it. Even I get pulled in to an “old” post)
    Williston[QUOTED] likes this.
  15. Sep 9, 2023 at 5:20 PM
    Williston
    New England
    Oops! lol. :facepalm:"Uncle Leo syndrome" I only noticed it after I already entered it all in and figured what the heck: it's good info to post once in a while.
    TnShooter[QUOTED] likes this.
  16. Sep 9, 2023 at 5:23 PM
    TnShooter
    Deogee
    STOCK
    True. Good post for people in the future that may come across this thread.
